Why Recirculated Air?
My air system almost always defaults to recirculated air; I like fresh air coming through the vents, whether I am using AC or not. I tend to set the temperature to 68 without the AC and around 71 when using the AC, but whenever I start the engine I always have to press the airflow button to get the airflow off recirculate. If I keep the thermostat at 72 degrees it will stay on fresh air, but that is usually too hot for me. Is there a way to keep airflow on fresh air as opposed to recirculated without keeping the temperature setting up so high?
Exactly on the money! All programmed.
I actually like the recirculated a/c mode as I live in NYC, air are not fresh here!!!!
Redliner: How is that a problem?? its just a touch of a button. Just like the staples button "That was easy!!"
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
lol well it's easy (as is the air recirculation button) just annoying to push every time I drive.
Sorry, could'nt resist.
Thank you all for the replies. I was hoping for some trick to override the Lexus brains. If I had the air system in the Auto mode, I could see it doing what is necessary to cool down the car the fastest way, but I just want to leave the unit on in the fresh air mode (with the air conditioning usually off because of the mild climate where I live). Oh well, I love just about everything else with the car so I can push the fresh air button each time I start the car.
RedLiner8...No default volume setting is a nuisance too...
Jlacck
09-05-15 01:57 PM
IStoSC
09-30-09 09:08 AM
2005, ac, adjust, air, auto, button, car, colder, flow, fresh, lexus, mode, recirculate, recirculated, recirculation, rx330, thermostat
