Found out why my steering wheel shakes and i have some questions
Hello everyone.
so i took my car into the mechanic to see why my car shoots to the left and i get a rattle in my steering at 60mph. it turn up to be the upper control arm ball joint is shot. ordered a new one . What else should i change in the suspension . i was thinking about greasable sway bar bushings. if anyone knows the size it will be great i think its 32 but just want to be sure.
Thanks
Thanks
If you want to change the swaybar bushings, go for Daizen Urethane bushings. Cheap and easy to install... Definitaly and upgrade over stock ones.
http://www.tmengineering.net/suspens...n/make/sc.html
Cheers!
Cheers!
Oups, wrong link!
Here it is...
With new upper control arm ball joint... And swaybar bushings, I think you're good to go!
Here it is...
Oups, wrong link!
Here it is...
Here it is...
also the front is 32 and the rear 19 is that correct?
No problems whatsoever.
Ok so i went to auto zone and i ordered. greasbale swaybar bushing kit from energy suspensions. i got one for the front and one for the rear. and i paid $20 for the front and rear. there poly bushing and should be good with cornering.
Let us know how it turns out...
gobears
05-25-07 08:39 AM
