Xm antenna install
Old 09-05-11, 01:48 PM
Habious
Habious's Avatar
Originally Posted by scyul
Habious, Could you please post some pictures of how you routed the wires... I'm looking at the trunk hinges and I can't figure out how you did it...
Here you go...hope these pics help.
If you need additional detail, just let me know.
Old 09-05-11, 01:58 PM
VVTiBob
VVTiBob's Avatar
The wire for the high mounted brake light come up the left luggage hinge and inside the nylon sheath.
File Type: pdf
Old 09-05-11, 01:59 PM
scyul
scyul's Avatar
Thanks for the pics...
So if I see correctly, from this point (red arrow), the wire just hangs down?
Old 09-05-11, 02:12 PM
VVTiBob
VVTiBob's Avatar
It is secured to the hinge with velcro wraps
File Type: pdf
Old 09-05-11, 02:20 PM
scyul
scyul's Avatar
Thanks for the pics Bob... I know how the third brake light wire is routed, what I'm trying to understand is how Habious routed his antenna wire...???
It seems to hang from the red arrow to the trunk...
Old 09-05-11, 02:47 PM
Habious
Habious's Avatar
Yes...when the trunk lid is up (backwards), the wire is tight (ish).
When the top goes down, the wire is somewhat loose.
The trick is to get the wire positioned so that when the lid closes, it doesn't pinch the wire in the hinge mechanism.
Old 09-05-11, 03:18 PM
scyul
scyul's Avatar
Great. Thanks for the info... I'm planning to install a backup camera on the trunk lid, between the spoiler and the L badge. I was wondering how to route the wires... Thanks again for your help!
Paul B
03-09-07 11:52 PM
twister
11-19-06 09:28 AM
is350matic
11-12-06 01:47 PM
Jace7
10-20-06 05:38 PM
stanatl
03-05-05 02:01 PM
Quick Reply: Xm antenna install
