Creaks in the front end when I'm turning while braking.
Old 08-17-11, 10:59 AM
husker741
husker741's Avatar
Default Creaks in the front end when I'm turning while braking.
I have noticed that although my SC is almost 10 years old, more creaks happen when i turn, say into my driveway, while braking. it happens in the front end, an although its not a problem, it is very annoying, and i just don't want any potential problems with it. anyone have the same issues? thanks.
Old 08-17-11, 11:05 AM
kjcole
kjcole's Avatar
I guess the usual suspects would be bushings, ball joints, tie rod ends, shocks etc. Expected wear items as the years and miles accrue.
Old 08-17-11, 11:08 AM
husker741
husker741's Avatar
thats exactly what i was thinking, i just didn't want anything else to be majorly wrong. thanks for the help!
Old 08-22-11, 09:22 AM
kjcole
kjcole's Avatar
Creaking while turning could be tie rod ends drying out. Jack it up, grab the tire 180 degrees apart and torque it (push with one hand and pull with the other). Clunking or movement with the hands horizontal usually means tie rods/steering, steering rack bushings, etc. Clunking/motion with the hands vertical usually means ball joints. Probably not springs since this isn't a McPearson strut design, but I'm certainly not a suspension expert.
Get a helper and you can usually narrow things down quickly.
FiveSeven
07-11-16 01:59 PM
ashtray
Suspension and Brakes
14
04-27-14 09:09 AM
GSRSRT
04-25-11 08:27 AM
lexusben
04-17-11 02:38 PM
Lexus082
09-29-07 05:22 AM
Quick Reply: Creaks in the front end when I'm turning while braking.
