What to buy for control arm bushings????
Old 08-24-11, 04:48 PM
farkas
farkas's Avatar
Default What to buy for control arm bushings????
After doing some research, I am finding that Daizen is for all purposes out of business since the owner has passed away. What are people now buying to replace their bushings with Polyurethane bushings? I am planning on changing bushings and ball joints all at one time.. Any info would be helpful
Old 08-24-11, 08:03 PM
jzwu
jzwu's Avatar
Guess only used ones but they are hard to find.
Old 08-24-11, 08:44 PM
cyberlexus
cyberlexus's Avatar
Check with Sewell parts, they have Polyurethane bushings for control arm
Old 08-25-11, 10:00 AM
redliner8
redliner8's Avatar
Looks like TM Engineering has Daizen control arm bushings for sale. I recently bought their Daizen sway bar bushings with no problems. http://www.tmengineering.net/suspens...n/make/sc.html
Is there a noticeable difference using polyurethane control arm bushings? I know the sway bushings made a difference.
Old 08-25-11, 11:46 AM
jerzylexus
jerzylexus's Avatar
my sway bar bushings from daizen squeal baad. kinda annoying
Old 08-26-11, 05:04 AM
farkas
farkas's Avatar
I believe TM Engineering is also defunct. If they are still open, the feedback that has been posted is not very favorable to them. Also unless they have a stock pile of Daizen bushings, they cannot get them either...
Someone must have found another source somewhere......
Old 08-26-11, 05:17 AM
redliner8
redliner8's Avatar
I ordered my Daizen sway bushings about a month ago with no problems. Someone else ordered from them more recently with positive results. Just speaking from experience although you're right, others have had problems in the past. Here's a list of dealers for Daizen, you can try contacting them and pick which you like: http://www.daizensporttuning.com/menu/dealers.html. If Daizen stopped making them, most of the time dealers will have a stockpile, so it's worth a try contacting them.
If you plan to DIY, take some pics and let us know how it goes
Old 08-26-11, 05:21 AM
redliner8
redliner8's Avatar
How long have you had them on? They may need to be re-greased, see if that helps
Old 08-26-11, 11:12 AM
harleydjce
harleydjce's Avatar
I have ordered from them with absolutely no issues and I'm outside the US!
This was recently as well.
Old 08-26-11, 11:38 AM
farkas
farkas's Avatar
I will try to contact them. Anyone have a phone number for them? All I see is Email.
Old 08-26-11, 12:06 PM
soarer93
soarer93's Avatar
You may want to make sure the BallJoints can even be replaced On the control arms.
for the sc300/sc400 they cannot be changed, you have to buy all new control arms. but the bushings can be purchased separately.
Old 08-26-11, 12:25 PM
farkas
farkas's Avatar
They are replaceable....The sc300-400 use a completely different Control arm....Plus the bushings are a real pain to replace in those arms...cut out or burn out! The SC430's are not bad at all to replace.
NoahAA
12-22-17 11:02 AM
KingNasGS4
Suspension and Brakes
24
06-20-11 11:09 AM
nuocmam122
02-12-04 11:23 PM
DIrEctQL
SC- 1st Gen (1992-2000)
18
12-04-02 03:00 AM
Quick Reply: What to buy for control arm bushings????
