Help! cold start issue
2002 Sc430 just turned 100K . On cold start car nearly stalls then for first few miles it is necessary to "caress" the gas pedal as the car bucks and acts as if it is not getting constant fuel flow. Problem has become progressively worse and independent mechanic can't figure it out after multiple attempts. worst after car sits overnight but any time the car sits long enough to cool completely, the problem is there to some degree.
Cleaned the MAF, it was so filthy I could not see any wires in the sensor until it was thoroughly doused several times with electronic parts cleaner. Tried cold start this morning and it seems to have resolved the issue. (Fingers crossed) but time will tell. Thanks to all!
So I thought the issue was resolved with cleaning the MAF. Car sat for 2 days in the garage and when it was started cold, it dropped rpm's then immediately kicked up a few hundred. When putting the car in drive after backing from the garage, the car again started to buck and sputter, and continue to do so for an extended time although it subsided significantly. the weather was raining and humid approx 80 degrees. any thoughts with the additional information?
If not, I would re-do it. Cleaning a TB is more than spraying cleaner in the opening and whipping it off with a shop rag. The gunk is behind the butterfly... To do a perfect job, the TB must be removed from the car.
I will pull the throttle body this week. Also, no codes are present and the garage scanned for any in memory? weather and temperature seem to have a significant impact on this condition.
https://www.clublexus.com/forums/sc-...down-help.html
I’ve also attached a couple of PDF’s of the fuel system that may be of some use.
