Need help with spacers
quick question guys my rears are from the 2IS therefore they are 18x8.5s should I go 25 mm all around then to avoid any possible rubbing with a 30-35 rear? I am trying to get this all done next week when I go in for my TTE spring install. I plan to do the drop + spacers + balance (slight vibrating 60+ hoping I dont have a damaged rim).
I have life time allignment at firestone so Ill get an allignment in about a month to let the springs settle a bit.
19mm all around seems like a safe bet if you are dropping it. Or maybe a 20 or 22, if the sizes exist.
