key programming
Old 10-18-11, 08:20 AM
kjcole
kjcole's Avatar
Default key programming
I have a remote transponder that works on my car. If I order a shell from Sewell (and they cut the key), then all I have left to do is program for the key (not the transponder) using the ignition/door coding actions that are listed on this forum, right?
I'm confused because somewhere I read that if you have a working remote that you don't have to program for the new key. But that doesn't sound right to me.
Can anyone confirm if I have to program the key once it arrives from Sewell and I put in my working remote?
Thanks,
kelly
Old 10-18-11, 10:50 AM
scdroptop
scdroptop's Avatar
If you have a transponder that currently works, all you have to do is pop it out, new/fresh battery recommended as well and put in the new shell and cut key you got from Sewell. I have a thread I'm about to finish regarding all of this that will hopefully be helpful because this can get tricky and $$$$$ too!
Old 10-18-11, 11:38 AM
mandyfig
mandyfig's Avatar
BTW, I have a copy of the programming steps for our SC. Directly came from the dealership. I actually did the programming of a freshly cut valet key from Lexus, using these steps. So it works.
Old 10-18-11, 12:15 PM
kjcole
kjcole's Avatar
Thanks droptop. That makes it easy. This is a transponder that I found under the seat (sans key/shell) after I bought the car in June. It needed a new battery and then all the functions worked. Nice to hear all I need do now is pop it into a new shell with the key cut for the ignition.
Mandyfig: Are the instructions for programming the key (not the remote) that you have the same as the ignition and door sequences that have been printed in this forum?
Old 10-18-11, 01:09 PM
mandyfig
mandyfig's Avatar
Maybe. But it is a series of door openings, whether they are identical, I can not comment without comparing the 2.
clubowner
IS - 1st Gen (2001-2005)
12-10-12 11:19 PM
djpolak
02-24-09 07:19 PM
bacov
RX - 1st Gen (1999-2003)
05-12-06 12:44 PM
tokhmeh
03-23-04 01:51 PM
gp1200x
01-05-03 10:29 AM
Quick Reply: key programming
