how to remove climate control device
So i've read on this forum that the climate control device comes out by just pulling it. But, i've had no luck. I've tried pulling as hard as i can, up, out, down. Prying on it, wiggling it. I feel retarded, can someone please throw me a bone.
It really does seem like it stuck.... but if you apply just the right pressure at the correct places it will pull straight back and out. Oh it's also help up to have a plastic removal tool to help you apply that pressure... Hopefully this diagram will give you the clues where it needs to be applied. In this case, diagram #2 shows the six pressure clip, which are, as you have found, pretty tight, so keep on applying outward pressure and it should pop loose..... Bone thrown! BTW welcome to the forum!.... if you haven't tried the Advanced search feature under Search in the menu bar, you can limit your searches to this sc430 forum and keyword.
I've seen this done several times (my job is usually to pass the tools and hold the flashlight, unfortunately).
One thing I do know is that this is NOT a "pulling as hard as I can" operation. You need to get the side clips to disengage. The homemade removal tool I saw was a putty knife. I'm told the trick is to use it without cutting the thin leather dash in the process.
Oh, and the climate control unit is over a thousand bucks, so don't mess that up either!
good luck, i had the same problem trying to get my Grom audio installed. I pulled so dam hard I thought i broke the dam thing in half, the front half of the panel seperated on me and the wiring broke loose, all was okay though, just plugged everything back in and the Grom audio unit is awesome.
Have to get this AC control panel out so I can take the Radio-CD unit out to get my jammed CD's out.
benwah (03-31-24)
Good tip on the rubber gloves.
I found that if you pull up and out and use a slight wiggle with constant even pressure increasing the presuure and wiggle as smooth as possible it will pop out. I then used light bulb grease on the clips and now its easy to pop it out and pop it .back. Its important to not squeeze it because you can damage the back light in the unit then you wont be able to read the digital information when its dark out
^^Another good tip. Keep it coming.
I thought after disconnecting the battery, you will have to re-set?
Maybe I should disconnect for at least 10 minutes?
I did it in probably 3 minutes, just enough for me to clean the terminal (the negative one) and grease it.
Any idea?
Where did you get the disgram
- where did you get the diagram? Thanks
Here's a video we made of the cluster and climate overview. It also covers the clips and sockets for the climate control.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
