Stock brake pads. non cross drilled or slotted rotors recommendation
Old 12-05-11, 09:30 PM
lexuz125th
lexuz125th's Avatar
Default Stock brake pads. non cross drilled or slotted rotors recommendation
Just bought my Factory brake pads, however need some help buying a good set of rotors that are non cross drilled or slotted. Mechanic shop says he can get me a set of 4 for $260, but in terms of the brand i dunno. He also said i might get them warpped early since they are non stock. Thought of that being a little odd.
Old 12-05-11, 11:11 PM
talwang
talwang's Avatar
Unless your oem rotors are worn down too far or have too much runout, just have them resurfaced and reuse them.
Old 12-06-11, 05:03 AM
iolmaster
iolmaster's Avatar
In all my years of driving and doing my own brakes. (I'm 59) I have never had to replace a rear rotor. they seem to last forever. Fronts are another thing. The OEM rotors from Sewell are priced very good with the forum discount. Like talwang said, are you sure you don't just need to have them resurfaced? New pads do not require new rotors.
Old 12-06-11, 09:14 AM
jzwu
jzwu's Avatar
I have resurfaced my front rotors. The shop will measure the thickness to ensure minimum thickness after resurfacing.
Old 12-06-11, 01:50 PM
lexuz125th
lexuz125th's Avatar
Car has around 100,000 miles never changed the rotors. When i press on the break, you really have to press down on it for the car to stop. The breaks dont make any noise or anything like that, just that the car is not that responsive when breaking.
Old 12-06-11, 04:22 PM
tentoys
tentoys's Avatar
i installed brembo's on my front. Also use them on my '99 land Cruiser. No problems at all. Fairly easy install.
Old 12-06-11, 04:47 PM
lexuz125th
lexuz125th's Avatar
Where did you buy the brembo brakes from? how much did they cost?
Old 12-06-11, 05:42 PM
Pnuge88
Pnuge88's Avatar
once you replace your front brake pads you should have a better response. or the fact that your brake system as air in it.. you should get a brake fluid flush done properly. I would say front rotors last about after two, maybe 3 resurfaces. Why not just stick with OEM rotors. as for the rear no one ever resurfaces them and just slap on pads.
Old 12-07-11, 04:32 AM
tentoys
tentoys's Avatar
if i remember correctly, i bought them from tire rack. don't remember the price but it was considerably less than OEM. just checked tire rack prices. $63.00 for front and $41.00 for rear.
Old 12-07-11, 07:23 AM
iolmaster
iolmaster's Avatar
The OEM cost is $95.00 per front disc at Sewell.
Old 12-07-11, 10:45 AM
lexuz125th
lexuz125th's Avatar
Thank you so much guys for your input, i really appreciate it.
engin_ear
Suspension and Brakes
03-27-11 08:41 PM
BlkSapPrl7
11-03-10 06:25 AM
cpachicka
26
10-13-10 10:41 PM
truenoboy
05-19-09 06:27 AM
Quick Reply: Stock brake pads. non cross drilled or slotted rotors recommendation
