Amsoil ATF instead of Toyota Type IV
I got great results using Amsoil signature series oil. My fuel consumption went from 10litres / 100km to about 8 litres / 100km.
I also change the diff oil, as the diff looks like it has never been done. Check out how much metal was collected from the magnet.
Now I am wondering if the Amsoil ATF can be used instead of the Toyota Type IV?
Anyone has actually done the change to Amsoil ATF?
Segullah (08-30-24)
Do you get any shutter with Amsoil when going up hills on light throttle and when the transmission shift to a lower gear?
I tried Transmax Z on a SC400 and this is what it did. So I reverted back to Toyota type IV and it was back to smooth shifting.
Thanks but not what I was saying. AMSoil ATF can safely be used instead of Toyota Type IV.
My 2006 SC430 requires Type IV as far as I am aware. My 2010 RX350 requires WS. 2008 onwards SC430's require WS frm what I can find out.
I will check when I get home next week!
I have been using Amsoil exclusively in our '02 SC since purchasing it with 15K miles 4 years ago. It now has 45 K miles. No issues whatsoever. No shutter. Just smooth shifting.
I use Amsoil 0W-30 engine oil and Amsoil synthetic tranny fluid. I change both at the same time. I drain the tranny pan and change whatever comes out. 2 Qts. of tranny fluid in the pan if I remember correctly.
Go for it!
Go for it!
To do a proper transmission flush requires a good 12 to 16 litres of ATF, ie (10-17 quarts). I don't think 2 quarts will do much but to dilute the ATF.
Understood. Never meant to mislead anyone. It's simply a way to slowly change the fluid out over time without a complete flush/fill. Since Lexus doesn't have a service schedule for the tranny in the SC it's better than doing nothing.
The following 2 users liked this post by tfeni52355:
ivanj (04-26-19),
Wilson2000 (08-31-24)
ATLQT IS Toyota WS
ATFQT IS Toyota Type IV
I think I have solved my transmission problem . I went to get the fluids changed out and I brought a 5-quart container. I think more was needed and any kind on hand was used in my vehicle. I am going to get this fluid changed out again. I have had Toyota/Lexus for years and I have just learned how important Dexron III is in the transmission and power steering fluid. The older I get the more I enjoy learning about cars and not to make costly mistakes.
ivanj (04-26-19)
Did Lexus recommend doing a flush on the SC430's? For other models they used to only recommended a Drain & Fill. Their thought was to not "stir up" anything that had settled and have it not get removed during the flush or break loose later. The drain & fill intervals were close enough that only replacing 2 quarts at a time was okay. I did that for years with my RX's and never saw problem with it. Now days with the "sealed" transmissions they are making a different statement on fluid changes...
Go for it!
Go for it!
I need to flush my tranny and get it changed next month. Which Tranny fluid should I use for best protection?
what is the difference between the Amsoil 0W30 as opposed to the signature 5W30 ??? I just put the signature 5W30 in my 02 Sc430. Should I have used the 030 8nstead?
The 2002-2005 transmissions are easy to do a simple drain and refill. The 2006-2010 are a PIA.
I would recommend you use the Toyota ATF although i have used Valvoline MaxLife ATF in many of my cars over the years with zero problems.
NOTE: recommending a brand other than OEM can become contentious so i will just say, its my opinion ;-)
