Eibach Pro-Kit Springs
I just found out that Eibach makes springs for the SC430. The part number is "8239.14".
I've always had good luck with this brand........improved handling, minimal effect in ride comfort.
Comments Guys ?
Comments Guys ?
I have an eibach pro kit set up on my SC400 and it rides decent. Actually, I've always used eibach's on my vehicles and was pretty happy with the product, but for some reason I tried H&R on my SC430 and IMO the H&R's ride much better.
My next step will be to get a set of Tein coilovers.
Daygo718,
Good choice.. Tein Flex is absolutely worth the money to get it done right the first time when lowering your SC.. The EDFC option for those coilovers isn't worth it IMHO..
Larry,
Eibach makes a good lowering spring but they wear out your OEM shocks fairly quickly.. If cost isn't an issue the Coilover route is the best solution..
joeyb,
Try using the SEARCH feature at the top of the screen.. Lots of good threads on Coilovers (Basically a single unit that incorporates the shock and the coil with the ability to lower or raise your car with supplied wrenches).. Hope that helps!
Larry,
joeyb,
DiauR1
IS F (2008-2014)
14
10-13-09 08:26 AM
mr_gs400
04-13-09 04:58 PM
