Blown Fuse
Hello,
Looking for help. I changed out my DRL's with IJDM leds. After changing them I heard a pop and figure it is a fuse. Now my traction control light is on and a few other lights. Anyone know which fuse I need to replace?
Thanks,
JP
Thanks,
JP
There are four fuse blocks in the car; engine compartment, trunk, front driver and passenger blocks too. Off the top of my head I couldn't tell you which one but, if you check your owners manual, all are labeled there. If you don't have the manual, it's available online at LEXUS OWNERS website.
Thanks for the help. I'll check through the manual. Once I find out the issue, I will post for help if other SC owners run into the same issue.
Jeff
Jeff
