Little bulb in headlight housing?? (2006)
Old 01-18-12, 03:48 PM
iolmaster
iolmaster's Avatar
Default Little bulb in headlight housing?? (2006)
I just got my D4S bulbs and have decided to change all the bulbs in the housing because it is such a PITA to get to the bulb sockets. There is a small bulb at the top of the housing that I do not know what it is. I think it is a #168, but what does it do? Any ideas? Also, I want to change the high beams to match the color temp of the HIDs to about 4300K. Should I just go with the 4100K Sylvania?
Old 01-18-12, 04:05 PM
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
If you're referring to the tiny wedge bulb that is in the same housing as your DRL/High Beams, that is your Parking Lights. Those lights are on whenever your headlights are on at night. If you want to change those out, go with these bulbs:
http://store.ijdmtoy.com/SMD-LED-Doo...tm&click=35328
For your DRL/High Beams, do you use your high beams a lot ?
Old 01-20-12, 06:04 PM
scdroptop
scdroptop's Avatar
I have these bulbs and I strongly agree/endorse them! They are a major PITA to get to as well! Go through the wheel well if you can. Turn the wheel towards the engine.
Old 01-20-12, 07:35 PM
SlvBullet
SlvBullet's Avatar
I just put these in a they look great. I also used them for the doors lights.
Pearl250
10-19-09 07:52 PM
TORTOISE
01-05-09 11:10 PM
rhsmd
02-05-07 05:26 PM
Nicelex13
05-20-06 04:23 PM
LEXO
03-28-05 09:17 AM
Quick Reply: Little bulb in headlight housing?? (2006)
