ECRU color touchup paint
You did not specify ecru interior part you're trying to touch up, or the year model. If it's a leather component here's one source for color dye/repair kits.. Or by using the Search and advanced search tool you could have found many threads on the subject. Here's one, probably the best, that is relevant for ecru leather touch up
It is on the door panel where the seatbelt has punctured part of the lower door panel. Also on the non leather part there are some small scrapes a touchup of paint might hide the mark.
The Ecru touch up will also be ideal for spraying the surrounding plastic trim.
