New antenna making grinding noise
Old 02-04-12, 12:46 PM
igorxx
igorxx's Avatar
Default New antenna making grinding noise
I just put a new antenna on a SC430 2002. It goes up and down okay but after it is already down it sits there and grinds for about 15 seconds. The noise and vibration is coming right at the base of the antenna (where the nut is). Any ideas what is wrong? The motor was cleaned out so I know there is no trash in the motor.
Old 02-04-12, 01:15 PM
VVTiBob
VVTiBob's Avatar
Was this a OEM antenna replacement? I ask because your description seems to indicate the motor is still trying to retract the antenna. Did you follow the TSB instructions for replacement? LEXUS TSB ON ANTENNA post #3.
Old 02-04-12, 02:05 PM
igorxx
igorxx's Avatar
Yes I did use the recommended method.
Old 02-05-12, 08:46 AM
Pnuge88
Pnuge88's Avatar
i replaced mine after destroying it in the car wash. it's installed properly but when it goes up or down its kinda loud. i just no longer use the radio anyway so it doesnt bother me.
Old 09-22-16, 04:51 PM
Wliping
Wliping's Avatar
igorxx, did you ever find a solution to your power antenna problem, I just replaced my antenna and it is doing the same thing.
Old 09-22-16, 06:05 PM
Bgw70
Bgw70's Avatar
this is an old thread...four years ago...click on link below and go to post 3 and open the attachment...let us know if it helps.
https://www.clublexus.com/forums/sc4...t-go-down.html
Old 09-23-16, 07:59 AM
jasone36
jasone36's Avatar
When mine failed, I simply had the mechanic disable it.
Strong FM signals are still okay, AM is non-existent.
Slvrtp
07-07-17 10:10 AM
karolgt
07-08-14 12:53 PM
rclab1
05-03-13 12:30 PM
Levistey0
08-24-06 10:22 PM
blau69
08-21-06 10:23 AM
Quick Reply: New antenna making grinding noise
