Wiring Tailights
hi guys
i have a 2002 430sc. my question is from the main harness it go's to a short harness and then to the tailights. i need to know the wire colors for short harness that plug into the tailight. which color wire is for directional, whch color is the park lights, which color wire is the brake light.
NEED YOUR HELP SOMEBODY MUST KNOW.
VVTIBOB YOU MUST KNOW.
Taillight LH = Gray
Taillight RH = Violet
Grounds = White with Black Stripe
SideMarker LH = Blue
SideMarker RH = Yellow
Grounds= White with Black Stripe
StopLight LH = Red
Stoplight RH = Red with White Stripe
Grounds = White with black stripe
Rear TurnSignal LH = Green with Black Stripe
Rear TurnSignal RH = Green with Yellow Stripe
Trunk HIGH mounted stop lamp= White with Green Stripe
Ground = White with Black Stripe
Source: 2002 EWD
StopLight LH = Red
Source: 2002 EWD
VVTiBob is the man!
I can confirm this:
When I tapped my side marker, these were the color of the signal wiring in the front.
I can confirm this:
