Cracking Sound Behind Vents when Accelerating Cold Engine
Hello,
I have a high mileage 2002 SC430. I have noticed that when I start the engine on a cold morning and start driving right away I hear a distinct "cracking" sound from behind the air vents (dash area) when accelerating. This only occurs when the engine is cold and when I am accelerating, this does not occur when the car is parked (I have not tried revving the engine when the car is parked, since it doesn't seem like a good idea LOL).
A a side note, I do typically move the temperature setting to the max of 85 degrees on cold mornings, but the cracking sound often comes up 5-10 minutes after I change the temperature setting. I'm not sure if this has anything to do with it.
Has anyone else experienced anything similar?
Sounds like the normal expansion and contraction of materials exposed to rapid temperature change, i.e. ABS plastics, polyethylene insulators, polycarbonate parts versus the colder metal frame/body parts. However, I have not experienced this myself since my car is garaged, and I live in a mild/temperate area close to the ocean.
With as many issues as you cite in your posts...it seems you have more than your average number of problems with this vehicle.
Might it be worth unloading and finding a different one if only for piece of mind?
Thanks for the responses. I choose to think that my car does not have more issues than most SC430s, but rather that I am overly thorough (read: paranoid) and investigate every single possibility of something going wrong
JMO...life is TOO short to be too paranoid.
I have an '07 model with the same sounds occurring and I can't figure out the cause. I've wondered whether it is related to the heating/cooling system baffles.
Anyone ever explored the baffles/system?
VvtiBob, you certainly bring up valid points. We should enjoy life while we can, and before gas goes north of $6 a gallon ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I personally get ~21 MPG, which is reasonable for a V8?
I have the same strange noise from behind the dash when accelerating. . At first it sounded like wooshing fluid going through the system. Now it's more like crackling marbles. I will make an appointment to bring it in to see what it is. It's a 2006 with only 19.3k on it. I purchased it new. I am under the extended warranty for 2 more years.
Just to update the people who were interested in this thread. I have an appt on Apr 18 to bring it in for the crackling noises. Tha's the earliest I can bring it in and be there to drive with the tech rather than just dropping it off and let him find it himself.
CHECK YOUR COOLANT LEVELS
its because there isn't enough in the system, and you've probably got airlocks and the like.
I had my expansion tank replaced (its slightly different here in the UK to the US) last year and had exactly the same noise.
Just needed topping up, this effectively removed air locks and noise stopped.
Its all to do with the heating/aircon system, sounds like you're accelerating on gravel or dropping a load of marbles - worried me first time I heard.
I googled to find solution,and topped up - which the garage advised me to do anyway as I suspect they were unable to fully bleed.
Thanks
Thanks
