Complete List of TSBs for SC from ALLDATA
Here's the link to all (or at least appears to be all) of the TSBs (titles only) from ALLDATA:
http://www.alldata.com/TSB/31/02311216.html
The TSBs for 14, 15, 16, 18, 22, 24, 26, 27, 29, 30, 34, 35, 37, and 38 are listed on the NHTSA website. The full documents for TSBs 15, 16, 18, 24, 26, 27, and 29 are available from NHTSA in .pdf form and I just ordered the others from them. However, it will probably be 8 weeks or so before I receive them. I'll try to figure out the best way to share them with folks once I receive them. I've included the links to the .pdf files for 15 (rear end clunk), 27 (operator error- opening both roof and back of trunk at same time), and 29 (CBEST settings) in other posts on this site that have been added to the FAQs by 2SAVVY, (Thanks by the way!).
I wanted to get a subscription from alldata so I could see the text of all these TSBs, however, they don't have subscriptions to 2002s available yet. I told their customer service rep. that it was frustrating to see the titles for all the TSBs but not be able to read them. He suggested going to a public library with an online subscription to ALLDATA to be able to view the TSBs. I'll probably just wait until I can get a subscription from them for the car next year.
Sorry if I'm providing way too much detail for folks. I, personally, just like to have access to all the information on my vehicle, knowing what to look for.
Robert
Robert
I'm getting all the TSB's straight from Lexus soon...I only have everything up to 1999 and 2002 GS430 and 2002 IS300. Yes, we will be posting them soon. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Ethan
Ethan
Bulletins for 2002 Lexus SC 430 V8-4293cc 4.3L DOHC MFI (3UZ-FE)
Service Bulletins
TSB Number Issue Date TSB Title TC001-02 MAY 02 A/T - Fluid Requirements
EL004-02 APR 02 Antenna Mast - Service Manual Supplement
PG005-02 APR 02 Tires - Inflation Pressure Adjustment
AU002-02 APR 02 Audio - No Sound From Amplifier
BO002-02 MAR 02 Tonneau Cover - Retractor Bracket Addition
PG004-02 MAR 02 Engine Cooling - New Pink Coolant
EL003-02 MAR 02 Air Bag Wiring Diagram - Manual Update
SS001-02 MAR 02 Drive Shaft - Tool: Nut Chisel
AU001-02 FEB 02 Audio System Amplifier - Installation Cautions
EG002-02 FEB 02 OBD II - Readiness Monitor Drive Patterns
EL001-02 JAN 02 Alternator - Fuse Application
PG002-02 JAN 02 Certification Label - Replacement Availability
PG001-02 JAN 02 Corrections Index - Repair Manual
SU003-02 JAN 02 Front Stabilizer Bar - Abnormal Noise on Turns/Bumps
SU001-02 JAN 02 Rear Suspension Member - Noisy
SU002-02 JAN 02 Stabilizer Bar - Torque Revision
PG003-02 JAN 02 VIN Plate - Replacement Availability
EL008-01 DEC 01 Electrical Wiring Diagram - Amended
SS011-01 DEC 01 Airbag Deployment Wire - Sub Harness
BO001R-01 NOV 01 Seat Belts - Extender Availability Update
ST004-01 NOV 01 Steering/Tires - Vehicle Pull/Manual Supplement
BO013-01 OCT 01 Cup Holder (Instrument Panel) - Available Separately
AU001-01 OCT 01 Audio Sound System - Inoperative/Erratic
BO012-01 SEP 01 Upper Console Panel - Installation Precaution
ST002-01 SEP 01 Steering Wheel - Off Center Adjustment Procedure
EL005-01 AUG 01 Door Lock Remote Transmitters - Programming
BO008-01 AUG 01 Retractible Roof - Operation Cancels
SS005-01 JUL 01 Diagnostic Tester - Immobilizer Functions
SS004-01 JUN 01 Diagnostic Tester - `Customize Feature'
SS003-01 MAY 01 ECU - Error Message During Flash Reprogramming
PG018-01 MAY 01 Tires - Precaution When Adjusting Pressure
PG014-01 APR 01 Spare Tire - Storage Kit Installation
PG013-01 APR 01 Tires - Dismounting With Pressure Warning Sensors
SU002-01 MAR 01 Wheels (18 inch) - Balance Adjustment Procedure
SS001-01 MAR 01 ECU - Flash Reprogramming Process
PG010-01 MAR 01 Compass - Initial Calibration During PDS
PG008-01 FEB 01 Rear Seat Belts - Securing During PDI
PG007-01 FEB 01 D/C Cut Fuse - Installation During PDI
PG006-01 FEB 01 Tire Pressure Sensing Transmitter - Activating Procedure
PG001-01 JAN 01 Front License Plate Mounting Bracket - Installation
PG002-01 JAN 01 Rear License Plate - Installation
Service Bulletins
The dealer isn't always very forward about the TSBs so it is always nice to go in there knowledgable about what is going on ahead of time and that there is documentation to prove it instead of being looked at like you are crazy...
When I wanted to get the doggone daytime running lights turned off the Larchmont NY dealer did not have that TSB altho it had many others, I had printed it up from this forum and pulled it out of my briefcase for them. Very handy. Also if you have nothing else to do some evening they are OK to surf through.
dealers won't tell you most of the time. they say there are too many to go through. you may have a problem but not realize it. just like the forum...what's normal.
