gps calibration after nav tool install
No there is only one antenna . My manual has a missprint. The GPS antenna is in fact up front under the dash against the fire wall. I would still question the installer. It just seems logical taht somethiing was missed during the install.
Good luck let us know how you make out
im away from my vehicle, wont be back till next week. as soon as i make it back, i will update CL on the outcome. thanks for the helpful info. you guys are absolutely amazing. thanks again.
im almost sure that the cable for the antenna thats in the front of the car was left unplugged, check if a little GPS icon shows up under the compass on the top left. If not then the antenna is not plugged in or has died. Mine died i hope you fair better. The NAV works both from your car's electronics such as your wheel speed etc and will also cross reference with the satellites so if its not doing that youll end up in feilds or in im case in the gulf of mexico.
found out why my gps wasnt tracking correctly. after inspecting all wires, found that the gps antenna was left disconnected. after connecting antenna, gps tracking works fine.
Where was it unplugged at ? In the trunk area behind the nav ecu .or if it was unplugged upfront where did it plug into ??. I have had my dash nav screen unit out several times and I have never seen a cable or antenna that plugged into it. The front nav has just two connectors plugged into it.
I would be curuious in knowing this
Buddy
Buddy
Good thing i don't use the gps in my car because i know were i'm going. i have no idea what your talking about. If i don't no were i'm going i'll ask someone and this way i don't have these problems you all have.
it was unplugged In the trunk area behind the nav ecu. the nav ecu harness & antenna were disconnected to install the nav tool & found the installer forgot to connect the antenna. you were right robertrios. thanks again.
I hope the installer was the one that had to fix it . If not I would be sure to send him the bill, There is no excuse for not plugging back in what you disconnected !
I know this an old thread,
Has anyone put eyes on the GPS antenna?
If so, what year is your car and where was it located?
Good reading, good Infos. BTW, how much does it cost for the back up cam?
Just for the sake of options for the video intergration, I will mention I used NAVIKS which is very similar to NAVTOOL. They are based out of New York's OneWayAutosports. Great customer support. Just thought it was worth mentioning. I don't get any referral points or anything, just for anyone weighing their options. I also got a fair priced camera through Walmart.com. Crimestopper 180 degree CMOS camera.
