Retracting Streering Wheel Creates Noise
I have noticed that when my steering wheel is retracting it makes a noise. This started recently with the quick change from very cold to very hot weather. A workaround would be to disable the moving mechanism, or somehow lubricate it so it doesn't squeak.
Has anyone else noticed this on the SC430?
Yep, I had this. It was the flexible cowl around the column rubbing against the dash. I just wiped it with some WD 40 (not sure if you have that in the US) silicone spray, problem solved.
Best regards
Steve
Jason,
Yes, this is a common noise and painful to listen to.
Steve,
Thanks for the diagnosis. I haven't been able to reproduce it in front of a mechanic and never took the time to track it down myself. So this will be useful to me this summer when temperatures are back above 110degF outside again.
Steve,
Jason,
Steve,
Steve,
ToyotaLexus
RX - 1st Gen (1999-2003)
01-21-09 06:02 AM
