Window Problem
05-12-12, 08:44 AM
Window Problem
The passinger side window will not work. Front fuse # 41 ok. Went to put window down will not work.
05-12-12, 09:11 AM
What happens when you try and put the top down?, does the driver's go down and the passanger not move?
05-12-12, 09:27 AM
when i try putting the top down both windows will go down.
05-12-12, 09:37 AM
Have you tried both the driver's side and passenger side switches? Could be a bad switch or loose connection.
05-12-12, 09:54 AM
driverside works properly pass. will not work only when i put the top down dose it work.
05-12-12, 10:01 AM
Sounds like there's a problem in the switch or a loose connection there.
05-12-12, 10:05 AM
I mean have your tried both switches for the passenger window? The switch located on the drivers side that operates the passenger window and the one located on the passenger door.
05-12-12, 10:12 AM
bob and liquid
how do i remove the switch plate on the doors been trying can't do
05-12-12, 10:20 AM
05-12-12, 10:55 AM
Just make sure to tape the pry tool so you don't tear the leather.
05-12-12, 10:58 AM
Did you make sure you do not have the drivers side lock out of windows set on lock out ?? Obvious but I have done this myself
05-12-12, 11:19 AM
how would i know if it in lockout. right now i have both sides out but don't know how to check them.
05-12-12, 11:47 AM
05-12-12, 11:56 AM
Drivers side window switchs One switch shows an image of a window with an x through it. Press that and see if the passengers switch now works
TXFM
09-07-24 10:12 AM
justin1203
04-26-19 03:06 PM
twisted1
RX - 1st Gen (1999-2003)
11-11-18 08:34 AM
omarston
Maintenance
06-17-09 09:20 AM
SloGS3
07-27-06 12:57 PM
