door lock cover
went to get some eggs this evening and realized the door lock cover is missing on the driver side door.WTF? got to the grocery store and shut the door.the door lock jiggled in the door.turns out the screw was just loose.i tightened the torx screw and all is fine.but now i am missing the door lock cover.doers anyone know if i can replace just the cover?if so does anyone have a part number? or a distributor that sells em? im so frustrated.also does the passenger door have a manual lock like the drivers door? or just a cover?
Assuming you're referring to the pre-painted cover...check at Sewell
http://lexus.sewellparts.com/oem-cat...C430-2003.html. If this is the part check your color code on the label located on the inside of the driver's front door near the latching mechanism. The part is 69250-50011xx xx=color code.
thanks Bob.i am going to sewell this weekend.i just replaced my power antenna with a mast i got off ebay and guess what?its broken again.this time its not my wifes fault though.anyway,gonna get me another one soon.thank for the info on the door lock cover.very very helpful.
jasone36
02-25-13 06:25 PM
