HELP - loud buzzing sound from dash
Old 08-21-12, 06:08 PM
vipergts
vipergts's Avatar
Default HELP - loud buzzing sound from dash
Hi All,
I have recently started to hear (at frequent intervals) a loud buzzing sound that can best be described as a phone vibrating/buzzing while its on a table. The sound happens every few minutes and is pretty annoying. It seems to be coming from around the navigation area or glove compartment - i cant pinpoint it. I turned off the radio and AC and the sound is still present. My Navigation Wood cover has been STUCK for a few months (doesn't come out and shut nor tilt) but not sure if that is the cause here. Any suggestions or help appreciated. What can be causing this sound?
Old 08-21-12, 07:48 PM
Harold57
Harold57's Avatar
What kind of buzzing sound is it? Could it be the cover or tilt motor coming on?
Old 08-21-12, 10:46 PM
VVTiBob
VVTiBob's Avatar
There is a history on the wood trim piece on the door. I believe there is even a TSB on it too, if memory serves.
Old 08-22-12, 05:28 AM
JohnnyCake
JohnnyCake's Avatar
Can you tell us the duration of the sound? Is it always the same length before it stops on its own? That's a clue and might tell us whether it is the cover motor cycling to close the Nav door.
If you kill the ignition, does the sound immediately stop?
Old 08-22-12, 08:05 AM
vipergts
vipergts's Avatar
Hi - sound comes on every 5-10 minutes, sounds like a loud cellphone vibration, it's not always the same length but is about 1-2 seconds in length. I have not tried killing the ignition as yet.
Old 08-25-12, 12:00 AM
jvfade
jvfade's Avatar
I have the same problem. My 2001 GS300 is masking this buzzing noise from the Dash area. My climate control servos used to make a noise like a rat was in the dash, but that has since gone away. Now when I start the car there is a buzzing noise that comes from the dash. It last about 15-20 seconds then goes away. The car is driving fine, and everything is working, so i'm guessing it is nothing major. If anyone has anyone info on what this might be I would appreciate it.
Old 08-25-12, 06:51 AM
barncat
barncat's Avatar
Now you have bees!
Old 08-25-12, 08:25 AM
Harold57
Harold57's Avatar
jvfade - same question as posed to the OP. Are your radio & / or NAV doors stuck? If so, is the sound that of the motor attempting to move the door?
Another question, what else is going on when the sound occurs? Braking, accellerating, cornering, just idling. There are functions / pumps related to each of those actions that could be your noise source and could be perfectly normal. Also, just how loud is the buzzing?
Old 08-26-12, 09:15 PM
jvfade
jvfade's Avatar
Non of them Harold57, just noise which is really bothers me.
Here is the video with sound
Old 08-27-12, 04:20 AM
mrblister
mrblister's Avatar
Hi All,
Is your car a sc430 ? Iam bit confused, I thought your car was a sc430 ? In your profile it says its a LS 430.
Old 08-27-12, 10:22 AM
Harold57
Harold57's Avatar
That is bizarre. I still have to question whether it is the NAV or stereo door attempting to move with possible stripped out gears though. I can't imagine what else it could be unless you dropped a cellphone down the a/c vents.
Old 08-29-12, 07:04 AM
grabber2
grabber2's Avatar
Did it happen when you have the AC on? I heard similar phone vibrating sound behind the dash when the AC is on.
Old 08-30-12, 10:47 AM
Habious
Habious's Avatar
Based on what I heard in the video clip, it sounds like your driver's side frangistrand is out of alignment.
I'd recommend a full fluid rotation and an exhaust stretch. That should fix you right up.
Old 08-30-12, 11:28 AM
vipergts
vipergts's Avatar
This is the EXACT noise i am hearing
Old 08-30-12, 11:32 AM
vipergts
vipergts's Avatar
Hi Sorry but whats a frangistrand ?
Quick Reply: HELP - loud buzzing sound from dash
