2002 SC430 Navigation Door
Can anyone help? My navigation door quit working, tilt function also, and it's stuck open. The Nav unit works fine. Dealer is telling me thousands to replace it - but I suspect it's like the Mercedes dealer where my SL was missing a $10 clip - and they wanted to replace the dashboard...
I'm hoping it can be repaired.
It makes a little "ping" sound then I turn the car off, but I don't hear the door motor.
Any help is appreciated!
After eliminating the potential of fuse issues then its on to other problem areas. Many times it's just comes off its track...other times it could be one of the motors. Either way it means getting into the guts of the center console ...are you up for some DIY work and diagnostics?
Thank you both for the welcome. I did check the fuse, from the kick panel in the passenger side, a 5 amp fuse labeled "TV". I thought that was the only one. The DIY is a little frightening but I'll give it a try. It's a Silver Belle, with the different wood, and I was worried that would complicate matters if I had to replace the unit.
Thanks again
Thanks again
Just had the same thing happen on our '02 but my dealer was a bit more (ahem) realistic about the repair costs. They took the car in (gave us a service loaner so we could go grab lunch and relax away from the dealership) and made very minor "adjustments and calibrations" and called within an hour that it was back working right again. When I pressed for more information on the fix he said that basically the door had come off it's tracks ever so slightly and just needed to be realigned. Our cost for this royal treatment...NOTHING! Free of charge! My advice...find another dealer!
Haven't had any success yet - it started working again and then quit?
I heard it might be the fuses, and there are two panels inside the car on either side of the footwell.
I'm going to try both of those.
Sorry for the late reply, hadn't checked board
