Last edit by: IB Advertising
Browse all: Steering and Suspension
- Are Spacers Safe?
Important information to help you understand your Lexus
How safe is it to add 10mm spacer
Just a follow up big thank you to WIL44(Steve), for the informations and tips provided. I finally finish the studs replacement on my car. A little side note, I knew my front driver side has after market studs on it, I later found out they are not the Lexus OEM hub so I can't use the studs I bought. The studs are the Honda/Acura size and I had to order 5 different ones for it.
The rear studs are actually pretty easy to get in once you know the trick, and Steve's photos are really a great help.
I end up using 10mm front and 15mm rear and the car looks pretty fair to me. Once I have the car clean up I will post some pictures for you guys' approval.
Look forward to seeing your photo's.
Best regards
Steve
