Old 12-12-14, 04:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
How safe is it to add 10mm spacer
Old 11-16-12, 03:12 PM
bb430
bb430's Avatar
Default How safe is it to add 10mm spacer
I am wanting to use a set of 19" wheels that have been sitting in my garage for a couple of years. Need some advice as to add 10mm slip-on wheel spacers to all corners without replaceing to the longer studs. Of course doing so for the look of the car. How safe is it? Anybody have done so without problem and fear of lug nuts come undone? Please advice, thanks.
The wheels are 19x9 ET40 and 19x10 ET45. I am using 255/35 and 295/30 tires.
Old 11-16-12, 03:17 PM
i2fat
i2fat's Avatar
I wouldn't recommend it. 5mm or less would be okay, but any more than that you are going to lose threads. Which is quite dangerous. I have 10mm on my wheels and I switched out the studs.
I would not risk it and I'm sure others will tell you the same. Pay the extra money or put in the extra work to have it done and have peace of mind
Old 11-16-12, 03:20 PM
SChema
SChema's Avatar
Definitely need to do wheel studs when going with a 10mm, you're only left with 3 or 4 threads with a spacer that size.
Old 11-16-12, 03:30 PM
bb430
bb430's Avatar
Thanks for all you guys' inputs. .
Just so I know, how long of the studs do I need to buy? Are you going to have any vibrations even though the spacers are hub centrics? Tires wearing more to the inside?
Thanks again in advance.
Old 11-16-12, 03:32 PM
2GSKaizen
2GSKaizen's Avatar
I've been told you need at least 7-8 threads MINIMUM to maintain torque correctly during heat and cooling cycles of the wheel. I think SChema is right. 5mm spacers work, 10mm will require the longer studs. I wouldn't risk it!
Old 11-16-12, 03:40 PM
2GSKaizen
2GSKaizen's Avatar
As long as they are torqued correctly, you should never have any vibrations with hub centric spacers. Lug centrics....thats a different story! I believe 40mm length is stock (correct me if I'm wrong guys) . A 45-50 mm should be good.
Old 11-16-12, 06:16 PM
mandyfig
mandyfig's Avatar
Always go with hubcentric spacers.
Old 11-20-12, 08:10 PM
robertrios
robertrios's Avatar
get the spacers that come with studs like the ichiba v2s or optionselects...ive been running 38mm in the rear with no issues/vibrations. I know engineers that have commented that during regular driving (not track) this is not dangerous. Of course changing anything will add some new element of failure but its small. tire patterns need to always be monitored as well but it really shouldnt be bad unless your also slammed and you drive like you stole it 24/7. Slip ons like you menioned are not work it IMO unless they are maybe 5mm and temporary...as mandyfig mentioned hubcentric or bust.
Old 11-21-12, 12:17 PM
WIL44
WIL44's Avatar
Hi bb430
I fitted 10mm spacers to the front and 15mm to the rear and used extended studs.
This is the link to my post that shows a good tip when fitting the rears.
https://www.clublexus.com/forums/sc-...l-spacers.html
Hope it helps.
Best regards
Steve
Old 11-21-12, 01:48 PM
bb430
bb430's Avatar
Thank you Steve for the link. I might need to do that eventually. Can you tell me what size(s) of studs you bought so that I have an idea. Thanks again.
Old 11-21-12, 01:51 PM
1sWt2GS
1sWt2GS's Avatar
wouldn't risk it.
i know people who have had their wheel fall off on the freeway, not fun stuff.
Old 11-22-12, 01:20 PM
WIL44
WIL44's Avatar
Hi bb430
The studs they supplied were 65mm long from end to end and the spline is 14.15mm dia.
Just make sure when you fit them that the stud does not bottom out in the lug nut before the wheel is fully seated. Some lug nuts do not have as deep a thread as others. Mine were ok, but they are not OEM as I have different wheels.
Best regards
Steve
Attached Thumbnails How safe is it to add 10mm spacer-img-20120602-00537.jpg
Old 11-23-12, 02:56 PM
bb430
bb430's Avatar
Thanks to Steve once again for informations provided.
I had asked several mechanics and all of them tell me to hammer the studs out. I am trying to find a C-clamp type stud remover and they were about $80 and up. I was told to use regular C-clamp to push it out, it might work with placing a BIG nut at one end.
How did you remove it(them)? Hammer time???
As old as my car is (2002), I am thinking they are on the hub pretty tight and dead.
Old 11-24-12, 10:56 AM
WIL44
WIL44's Avatar
Hi bb430
They come out very easy with a club hammer. Very little force required, no need for a clamp. Mine is a 2002 too.
I used an old lug nut and a socket (pictures in my thread) to pull the new ones into the spline. Torque you wheels and recheck them a couple of times after driving to make sure they are seated. Mine didn't loosen at all.
Best regards
Steve
Old 11-24-12, 11:54 AM
bb430
bb430's Avatar
Thanks for your input Steve, I am waiting for my studs to arrive then get started.
Quick Reply: How safe is it to add 10mm spacer
