pairing phone to bluetooth
From the '06 Navigation Manual:
(a) Enter the Bluetooth phone
To use a hands-free system, you need to enter your phone in the system. Once you registered it, you can make a hands-free call.
1. Push the “INFO” button to display the “Information Menu” screen.
2. Touch the “Telephone” switch to display “Telephone” screen.
You can also push the telephone button to display this screen when the vehicle is stopped.
3. Touch the “Settings” switch to display “Settings” screen.
4. Touch the “Add Phone” switch to connect your cellular phone to the system.
5. When this screen is displayed, input the Passkey displayed on the screen into the phone.
For the operation of the phone, see the manual that comes with your cellular phone. If you want to
cancel it, touch “Cancel”.
6. When the connection is completed, device name and Bluetooth Device Address is displayed.
You do not need to enter it in case of using the same phone.
I can't imagine it's much different for other phones vs. an iPhone. Once you find the Bluetooth on/off switch within your phone and then search for devices and once found, put in the code, you should be paired.
iluvls460
02-19-08 07:10 PM
