Flush Mount on OEM 18" SC430 Rims???
From my knowledge the Sage Front RCA Kit
30MM Front RCA Kit (Almost 1.20 Inch Drop)
40MM Front RCA Kit (Almost 1.60 Inch Drop)
The SAGE Rear 30mm RCA Kit with Camber Correction adjustment.
The SAGE Rear 30mm RCA Kit offers 3 settings to correct Negative Camber. Depending of the Insert Block selected, you can add +1 degree, +2 degree, or +3 degrees of POSITIVE Camber.
Oh you've already installed it haha. I mentioned the car was already low enough with the sage kit! What are you rubbing on? A little heat gun and rubber mallet should fix your problems on stock wheels. I didnt have no rubbong at all since i was setup for aggressive wheel fitment
Sorry to bring this thread back to life, did the 30mm front sage kit take care of the rubbing under hard braking? And would you happen to know where it was rubbing?
