Now if you just change your DRL to LED, then the look is complete! No more of the "yellowy-orangy" stuff.
I installed. I believe ( VLeds) for a SC430 into my SC300 and I noticed one night when I was going down a very very dark road that when I activated the HighBeams the light output was below average.
So can I just disconnect the radio antenna? Sounds like FM still works, I don't care about AM. I don't need to shave mine, as long as it stops telescoping. lol.
I had a set of 19" Rims & Tires that came with the SC. The tire size was 245/40/19 verses 245/40/18 which is 25mm taller than the Stock Tires. I chose to install those onto the IS-F front Rims because I like the fact that there would be more meat on the Rims and because of the fact that I would later be installing 275/35/19 Or 285/35/19. These are the closes match
245/40/19 OD = 679mm
275/35/19 OD = 675mm
285/35/19 OD = 682mm
Also the IS-F wheels came with 255/35/19 OD = 661mm so the SC is not sitting right. The tire would be replace shortly.
Tire spec.
Stock Tires
245/40/18 OD = 653mm
IS-F Rear Tires
