LED Conversion Project
#31
The LED for the License is done:
#33
HID+Fogs Fogs have to be LED's...
HID+High beam...not bad...
#34
Great job Mandy, your car looks awesome.
Best regards
Steve
Best regards
Steve
#35
Thanks Steve, how's the weather on the other sider of the pond? Yesterday was a top down day but we took the wife's Miata. Today's a great day as well. Need to take the SC for a spin.
#36
Probably be another three months before I get the top down again!!
I took her out for a drive on Saturday, but going by the weather forcast, she will more than likely stay put for awhile.
Best
Steve
#37
Steve,
What did you replace the fogs with? They look nice.
Mandy
Mandy
Thanks Mandy, its bloody snowing here...........and I didn't put the cover on her before it started, damn!
Best
Steve
Best
Steve
#38
Steve,
I like this set of fogs...
#39
Hi Mandy
My fogs have been replaced with round LED DRL's.
I took off the bumper and removed the existing fogs, made brackets for the new ones and fitted them to the same fixing points.
Made a perspex cover that I glued to the back off the foglight trim which I sprayed body colour.
Job done.
Few pictures.
Unfortunately I did not take pictures of the brackets as it was just a test, but it worked out fine.
You can just see the brackets in the picture before I put the cover on. Sprayed them black so you cant see them.
Best regards
Steve
Job done.
Few pictures.
Best regards
Steve
#40
How did you access the fogs? I was stumped on this and did not do the change over. Any help would be appreciated. Thanks.
#42
As Slv Bullet said you will need to drop the bumper.
We don't have DRL's built into the headlights in the UK so as I rearly use the fogs I decided to change them to DRL's.
They are on whenever the engine is running unless the headlights are on, then they go off.
Best regards
Steve
#43
Thanks, guess the LED is not going to the fogs, for now. I know that i does not take a lot to take the bumper down. But is a 2 man job.
I took off my RX330 bumper to repair my headlamp leak. So I really should not fear the SC's. I have done a Maxima, front and rear as well.
#44
It is not a two man job, it's easy.
The only tricky bit is where the bumper meets the fender, there is a clip that you have to be quite forceful to pull the bumper away from, bit of a knack to it.
Cheers
Steve
#45
Hi Steve,
I am closer to taking it on...a bit more nudge.
Thanks.
Mandy
Thanks.
Mandy
