lexus logo projector puddle light
#46
Turbo did you install your door projectors near the courtesy door light ? I plan to install mine more in the middle near the speaker in one of the wider plastic sections.
I think my projectors may be a bit smaller. I think more in the middle for me will drop the projector a bit lower thus the projected image will be a bit smaller on the ground and may have better focus
If you drill anywhere else then u r stuck to the projector light 4ever
Trust it will burn or die no more than 6 month
About the size of the reflection ... I think that there is a plastic circle that if utturn right or left it will modify the fucus
#48
Yeh I figured you were less then 12 " maybe 10 " because above that and the logo is just large to see in day light.
Its a cool toy and is best used or seen in night time. I plan on installing but I am waiting till weather is better. Have you pulled your door panel off ever. I am not sure I remember how to disconnect the lock cable and the door push rod from the handle. Any advise for me on doing that.
Buddy
Buddy
Here are the steps:-
1- Pull out the door courtesy light assembly. any Flat screwdriver will do the job. Then separate the light cover from the assembly.
2- Drill the cover.
3- Fix the projector.
4- Connect the wires
5- Fix back only the light cover with the projector attached to it.
6- Make your final adjustments.
7- Glue the assembly.
Note: fixing the projector this way will save you the hassle of cleaning its lens every time if it was installed outside the car and exposed to dirt, dust and water. Also this way you can at any time remove the projector and buy either a used or new door light assembly and it won’t cost you much. moreover, if you drill anywhere in the door panel or the door assembly, then it will be very difficult to cancel the projector, very expensive and you need to remove the door panel to connect the wires thru the new place.
here are some pics to help:-
![lexus logo projector puddle light-20130409_084500.jpg](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/279340d1461123025t-lexus-logo-projector-puddle-light-20130409_084500.jpg)
![lexus logo projector puddle light-20130409_084803.jpg](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/279341d1461123025t-lexus-logo-projector-puddle-light-20130409_084803.jpg)
![lexus logo projector puddle light-20130409_084807.jpg](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/279342d1461123025t-lexus-logo-projector-puddle-light-20130409_084807.jpg)
![lexus logo projector puddle light-20130409_085006.jpg](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/279343d1461123025t-lexus-logo-projector-puddle-light-20130409_085006.jpg)
![lexus logo projector puddle light-20130409_085056.jpg](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/279344d1461123025t-lexus-logo-projector-puddle-light-20130409_085056.jpg)
#49
Turboo, you are the man!!!!
Great concept, idea. Am all in.
#50
No Need to pull the door panel...Just pull the courtesy light assembly.
2- Drill the cover.
Attachment 279340
Attachment 279341
Attachment 279342
Attachment 279343
Attachment 279344
2- Drill the cover.
Attachment 279340
Attachment 279341
Attachment 279342
Attachment 279343
Attachment 279344
#51
2- Drill the cover.
Attachment 279340
Attachment 279341
Attachment 279342
Attachment 279343
Attachment 279344
2- Drill the cover.
Attachment 279340
Attachment 279341
Attachment 279342
Attachment 279343
Attachment 279344
#52
Thanks in advance for the pics and tips mrblister!
#56
#57
Thanks Turbo I liked your idea. My plan is still to mount in my door panel since I believe they will last longer because mine auto shut off after a few min. in the event they don't I could buy another set . Where they locate is actually not in an area that will get direct dirt on them when the door is closed there actually in a sealed area . I figure if they stop working I could just leave them in place or else just install a regular led light and then I would have a real puddle light to illuminate the ground. The only pain is I will have to install a two wire connector so in the event the door panel has to removed by me or dealer it will be apparent that the added puddle light has a male/female connector that has to be unplugged if you want to take panel completely off. I will post full pics as soon as I do it. Please let me know how yours hold up.
A friend had install it like two month ago the same way u intend to do...till now it is still holding and working fine
#58
If the distance is to much to the floor I noticed that it is not clear ( l mean the rainbow circle)
Also there is like a ring on top of the projecter that if you turn it will adjust the focus. But be careful not to move it too much or hard as the lens might break easily.
#59
Turboo, just to ask more deatils on how you cut through the lens, can you please explain exactly how you did it? Did you use a clamp, etc...
#60
First cut was good but too much tight..so I just drill again with little more force on corners. Maybe if I used something to hold the cover while drillig it would be safer and better from the first time.
