trd rim tire 19x8 +37 anyone have these?
Old 03-10-13, 05:25 PM
fj40ih8mud
fj40ih8mud's Avatar
Default trd rim tire 19x8 +37 anyone have these?
Found a set of these pretty reasonable.... anyone know if they fit?
19x8 +37 backspacing
Attached Thumbnails trd rim tire 19x8 +37 anyone have these?-ag_08xb_trdwheeel.jpg   trd rim tire 19x8 +37 anyone have these?-trd-19-in-5-spoke-wheels-405x225.jpg
Old 03-10-13, 09:23 PM
texsexlex
texsexlex's Avatar
...those should fit without any issues
Old 03-10-13, 11:15 PM
SSK0771
SSK0771's Avatar
Yes the wheels will fit NO Problem but the offset is too conservative. It will look little too tucked in. I would get some spacers if I were you.
Old 03-11-13, 10:46 AM
fj40ih8mud
fj40ih8mud's Avatar
Default Thanks
Any idea what size spacer or what company makes a good spacer?
Tires are 225/35/19 Nitto
Old 03-11-13, 09:31 PM
SSK0771
SSK0771's Avatar
First of all, your tires are way too small. You need at least 245-35-19. The diameter of the tires are way off.
As for spacers, it depends on how aggressive of offset you want. In the front you can go as high as 20mm. For the rear, you can go even higher but I don't recommend THICK spacers.
As your brand, I had Kics before but there are other brands too like , H&R. Try to do some research.
I was never a big fan of using spacers. I always try to use the right size tires with right offset on the wheels.
Old 03-12-13, 07:02 PM
fj40ih8mud
fj40ih8mud's Avatar
Enough said, I will pass on these. Thanks for the advice.
JDW379
08-03-14 09:50 PM
Split2nd
04-14-12 11:27 PM
kingbigs11
03-08-10 07:24 PM
nosjunkie
02-25-09 03:09 AM
boxbrownie
RX - 1st Gen (1999-2003)
01-18-08 09:24 AM
Quick Reply: trd rim tire 19x8 +37 anyone have these?
