Rear Window Mod
You can do that as well You will have control of the rear windows and can put them up or down regardless as to where the top is as well as where the front windows are, If top is up and all windows are down its best to open the doors when putting rear windows up then put front windows up. I believe there was some discusion about doing it this way so as to not wear out window seals. In normal top down function the front windows drop first then the rear windows go down last. When closing top rear windows go up first then the fronts.
ok I see. I sold my luxlink a month ago and i'm doing the rear window mod for the backs to go down with top up not to bad a job, was not sure if you could put the rear window down with the top up with lux link thanks
Luxlink if equiiped with the qtr window has full control of the rear windows, no matter wha settings on the top. It was a $75 add on?
Can not wait. I want to do the same. Like you, I sold my Luxlink.
mandyfig
one of the parts must come from china, take about two to 3 weeks need two relays the other part is from Tx.
the relay can't be had in the states.
