Pwr / ect / snow ?...
I know that the PWR mode changes the throttle sensitivity. Does it do anything else like changing shift points, downshift points etc?
I can't find anything in the owner manual other than "for powerful acceleration and driving in mountainous regions"
Does anyone know what it really does?
JR
JR
Odd thing I heard - someone said it actually helps fuel efficiency when you are in Pwr mode. I left mine in pwr for the last 6 months and it seemed about the same to me. MPGs were certainly not worse than normal mode and throttle response is better. So I am keeping it this way.
the PWR mode changes the shift points and throttle response, SNOW starts the car in second gear for better traction in snow, and etc is just normal from my understanding..
I may be wrong about this but, I was under the impression that "ECT" wasn't a mode...it was the name of the switch.
It's the "Electronically Controlled Throttle"...and it has 3 positions - Power, Normal, and Snow.
I will switch on my ECT and try it for a few hundred miles. I occasionally turn it on anyway when "conditions" exist, and drop the gear to 3 and then upshift to D. Have not tried 2 and do the C shift.
There is a difference in throttle response.
My LS has the same PWR-NORM--SNOW switch. When I switch the LS to Snow mode there is a much more dramatic reduction in throttle response. It's not so dramatic with the SC430.
In Normal mode i find that my LS is excessively sensitive. When I have passengers I find myself going into Snow mode with the LS. it makes the throttle is more controllable. The SNOW mode in the LS has a dramatic effect on throttle response. If I switch it while accelerating its like I instantly reduced throttle by 1/2.
So my "normal" driving setting is PWR for my SC 430s and SNOW for my LS460.
Of course, when pulling onto an interstate on ramp I stomp the pedal to the floor at times and enjoy the acceleration. It seems to blow out the cobwebs and it keeps the car running very well.
JR
I read that ECT stands for Electronically Controlled Transmission. This button controls the power to the transmission. Pressing Power makes the transmission sensitive on take-off. Snow Mode reduces the likelihood of tire slippage in snowy weather. This mode makes the car feel as if it starting off in 2nd Gear.
JR
JR
At a stand still, set the ECT in PWR mode. Step hard on the acceleration pedal and your SC will take off. Watch the tachometer you will see the first gear shifts around 4400 rpm, then the second gears is shifted around 6000 rpm and so on....
I have never experienced with any car that goes faster than the SC, so I can not say if it's fast.
For me, it's fast enough. It is not my habit to do this. Just one or two times to feel the power of the SC.
