Had a couple pics to share- are these normal?
Old 05-06-13, 07:19 AM
fj40ih8mud
fj40ih8mud's Avatar
The Rockford are 8 ohm as well
http://www.rockfordfosgate.com/produ...?itemid=223201
pss-8-6 8 ohm.
the magnet is massive!!!
Old 05-06-13, 09:41 AM
bacardi11
bacardi11's Avatar
mrblister
my sub is a 4 ohm with a focal1 amp and I use a polk db 840 4 ohm this all tied into the stock amp.
can't get anything but the stock 16 ohm sub so I use a different amp for the sub.
Old 05-06-13, 09:53 AM
bacardi11
bacardi11's Avatar
guy
all speaker in our cars are 8 ohm and 16 ohm sub. if you want to use a different speaker for the sub you must use a sub amp for the sub. or change your system.
Old 05-06-13, 10:41 AM
fj40ih8mud
fj40ih8mud's Avatar
What is a good replacement sub? I did not pull the rear seat upper out but could see a pile of black foamish stuff under where the sub is, so it is time.
Old 05-06-13, 11:12 AM
bacardi11
bacardi11's Avatar
fi4
I use the 8" polk db 840 ohm perfect fit but you must use another amp tied into your stock amp.
Old 05-06-13, 10:10 PM
texsexlex
texsexlex's Avatar
Originally Posted by bacardi11
mrblister
the stock speakers are ( 8 ohm ) not 4 ohm if they were 4 ohm I would have used the 4 ohm Dc Gold.
...the Boston Acoustics that replaced my ML's are 4 ohm
Old 05-06-13, 10:15 PM
texsexlex
texsexlex's Avatar
...I'm also running a 10in-P2 Rockford Fosgate sub, with a Rockford Fosgate Prime R1-500 amp
Old 05-16-13, 07:57 AM
fj40ih8mud
fj40ih8mud's Avatar
Default another pic
I know that this car was originally in Dallas, Texas. Here is what I found in the trunk.
Attached Thumbnails Had a couple pics to share-  are these normal?-img_6603.jpg
Old 05-16-13, 09:45 AM
mrblister
mrblister's Avatar
Look for one of the Dallas Cowgirl Cheerleaders or Coach Landry's Hat
orateam
HS 250h Model (2010-2012)
25
02-05-24 05:07 AM
mdk87
ES - 6th Gen (2013-2018)
34
10-27-21 03:47 PM
dkotanto
GX - 1st Gen (2003-2009)
25
04-29-19 07:06 AM
mikeohhh
NX - 1st Gen (2015-2021)
01-03-16 01:21 PM
416tt
12-31-13 12:58 PM
Quick Reply: Had a couple pics to share- are these normal?
