LED Eyebrow Lights
Here's the pic:
I didn't drill any holes in my car to put on the eyebrow lights. There is a hole in the firewall near the steering column. It is covered by a rubber plug about 2 inches in dia. i just stuck a coat hanger through the insulation . It comes out near the emergency brake pedal. Then I just put the plug back in over the wires. I put a small LED on the bottom left side near my brake so i could know if the lights were on or off. In the picture the only lights that are on are the eyebrow lights.
I am thinking of going with these lights from ijdmtoy thus need drilling. I haven't decided if I should put them in a straight line by the fog light or in an eyebrow shape under the headlight. In either case I will probably end up putting more than 5 on each side.
Which one will look better? Opinions.
Cheers.
Cheers.
I guess it is up to you which looks better. I don't see why you will have to drill holes if you put the eyebrow lights on. They stick to the car and you just hid the wires.
Well, yes and no. I have them hooked up to an empty spade in the fuse box that is switched with the ignition. The LEDs are on any time the ignition is on. I currently have a switch next to the fuse box if I want to turn them off for any reason. I eventually plan to locate a switch inside the cabin for easier access.
StillLine
StillLine
StillLine, this looks very OEM!!!
This is great, care to tell us where you purchased the LED's? And how much?
I take it that the bumper had to come off?
Thanks.
Thanks.
$14.88
No, very easy to install. Check out this link for more pics and info.
StillLine
StillLine, thanks!
Bam! Got my set!
It is so thin that I see no problem. The SC and the RX will have a set!
Can not wait.
Bam! Got my set!
Can not wait.
