DVDNAV Media Integration- NAVIKS
#46
Really can't tell how a RCA plug video source would look..is it CRT quality, aka 420 vert. res? How crappy is it? Granted, you're not going to be displaying HD quality with RCA cables but I thought I heard the display (NAVIKS) could lop off a bit of the picture, at least for iphone vid.
It seems crazy that this device didn't have mirroring for ipod video/tablet etc. It must have been designed bout' the same time as the SC430. I think they're out of production.
#47
I'm also not clear why the company which utilized the dvd nav player for video was taken off this site. Obsolescence? Did people have to give up nav in order just to play one weenie dvd?
#48
Just an update. My setup is still working perfectly. No problems at all. I know there are a few people who have messaged me looking for the EagleTech/Arion Bluetooth Receiver that I am using. They have been hard to find, but I did find a replacement for those that still want to add Bluetooth capability for music and phone/speakerphone integration. Naturally, you would either add a cassette adapter so you can use the 3.5mm, or go with the better quality VaisTech SL3U for a dedicated 3.5mm AUX input. In any case, this bluetooth control lets you forward and reverse the music track/playlist from your phone, as well as take & make phones calls without every having to remove the phone from your pocket or jacket. It also has a rechargeable lithium ion battery for long life (I charge mine about once every other month- usually one full charge will give me 6 hours of full playback). Another benefit, it that it's also small enough to mount easily within reach of the steering wheel and keep a clean look to the interior. Honestly, the best thing is the track remote. I don't have to pull out my phone to switch to the next track or to play the track again. I haven't tried this brand per se but seeing how mine is quite similar, I don't think this would be a waste of money.
https://www.opensky.com/mobileheads/...7&mid=74636392
#49
Uploaded some videos of my setup a while ago... thought I'd link them here....
https://vimeo.com/user54620921
http://www.break.com/video/ugc/sc430-3037080
#50
You are a tech genius…
I followed your adventure and you certainly deserve applause. I could never even think of tackling that job and I am petrified to let someone take the car apart. I have watched some u tube videos on SC 430’s. Installing all that metal in and out around the beautiful wood. I might have missed it, do your two wood doors still open and close? (I hope this print does not stay so small and that you still visit this forum.). Your description of your work was outstanding and I see you being a tech writer some day. S
#51
As for a tech writer position, I'm in Healthcare but tinkering with electronic and the SC430 has always been a hobby. This forum has been so useful for so many of my projects therefore I try to build DIYs for anyone that in interested in following suit. LMK if you have other questions.
#55
Thank you Siddu for answering all my questions on the Naviks https://naviks.com/i-24077150-2002-2...n-control.html. Thought I'd post your PM response below - could be useful to other members. With your information, the Naviks option would NOT be for me due to (a) having to manually switch from OE to Naviks at every start, (b) Carplay signals audible only when the Lexus OE unit is in either FM mode, or a cassette tape inserted/spinning, or a CD inserted/spinning with discernable sound quality rather than a dedicated auxiliary link/channel to the Lexus OE, and finally (c) the Lexus OE navigation screen not responding as prompt.
- Is it easy to install? Yes, it's easy to install, I did it when I was around 1x years old, so it's not that complicated. The hardest part is to route a few wires from the trunk to the center console. I did it by running the cables behind the right side panel behind the passenger door, running it under the seat, and through the back of the center console assy. to the back of the radio. That made it really easy. No electrical work other than basic harness plugins needed to be done.
- Is it true that the Naviks interface required the original SC430 radio head unit to be in FM 89.5 mode for it to function? How is the sound quality if it is broadcasted/processed as FM signals? No, as long as the radio was on in any mode, sound would play. However, when CD and Tape was selected, it was much better than FM (possibly due to the FM bandwidth itself). I left a blank tape in the slot so that I didn't have to hear anything before I selected the NAVIKS input (you have to do it every time, biggest annoyance).
- Is there any latency after you started the engine or turned the key to Accessories? Yeah, the biggest annoyance about the system was that, whenever you start the car, it defaults to the OE system. To get NAVIKS on the screen and through the radio you have to hold the button for something like 3 seconds each time.
- Does the resolution of the SC navigation screen give you decent clarity? Yeah the SC screen is about as good as you would expect. But honestly, after I messed with the contrast/brightness on the screen and the NAVIKS menus individually, I got it pretty nice. here's an example of mine.
- What are the best/worst things about the Naviks interface that you like/dislike? Honestly, it was exactly what I wanted and needed. Biggest annoyance: you have to switch to it every time you started the car. Second biggest annoyance: it took a decent amount of effort to swipe to the next page on carplay. The touch works about as well as it possibly can. Carplay usually doesn't make you rely on swipe gestures to use it. they are possible, but it's hard to swipe to the second page since you kind of have to swipe on the bottom of the screen which doesn't register as well. i got around this by customizing my carplay homepage using the phone, and i put all my important apps on the first page.
Bgw70 (04-08-23)
#56
Hi Bgw70, I've read through many of your comments/posts on the work you've done to your 2 SC430's. I have a 2004 SC430 @59K miles and in fantastic original condition - I'd like to keep the car as stock as possible but as you've seen from my other post, not liking the Naviks option (switching at every start and latency, sounds going through FM, cassette/CD inserted/spinning . . .) I have looked at the Pioneer DMH-W4660NEX but then again, wanted to keep stock. In the end, all I care to have is to be able to blu-tooth and wired stream Spotify, Pandora, Apple/Waze maps without replacing the OE head unit or the OE navigation - do you know of any simple aftermarket options/modules I can plug and go? All else failed, might need to explore the Pioneer DMH-W4660NEX again (would miss the CD option for sure). Thanks for your help.
#57
Both of my pioneer radios have a CD player…I really like the unit in my 2007, red SC430.
BTW, I know my PM box is full…thanks for reaching out 😊
#59
Thank you so much Bgw70 for your response (yep, tried your PM box first ). I will peruse through your '07 work again and if any questions, hope you don't mind me reaching out again. Take care.
here is the 2007 install
https://www.clublexus.com/forums/sc4...007-sc430.html
#60
Thanks again Bgw70 for your willingness to help (PM is still full ). A couple of quick follow up questions that I would love to hear from you or other members . . .
- What does the Beat-Sonic MVA-12L ($430) do that the Metra wiring kit (supposedly would allow for the steering wheel control to work) would NOT do?
- If I were to use the Metra wiring kit, would the OEM Nav still work?
