Recall for 02-04 Sc430
#121
UGAALF, did you replace the headunit? If so, which one did you go with?
#122
I went with the Kenwood. I dont have the model number with me, but it has been discussed in previous threads. I do not have steering wheel controls, but overall I am pleased with the unit and its performance.
#123
Now the ac doesn't work
I brought my 2002 SC430 in for the recall and it needed it done.
I got it back and all seemed fine for about a week, at least I didn't really notice anything. Then I began to notice I seemed to be getting alot of hot air out of the vents at my feet and on my dash, even with the climate control off. For several days I just closed the dash vents (which I never did before) and the feet were fine because it was brisk out.
The the weather started to change and I noticed I was so warm I would have to open the window a hair even with the climate control off. Then two days ago I tried the AC and all I get is hot hot air. The fan works just fine, the AC light comes on (no blinking) but I just get 100% hot hot air no matter what I set the temp to. It wasn't like this all winter because I would use the defrost and reduce the temp down and it would be cooler than the hottest temp. Now I can't get the defrost any cooler.
I checked every fuse and swapped relays and nothing. The AC compressor does not engage.
Just a coincidence or could they have not connected something during this recall repair? I called the dealer and their first response was "Oh there would be nothing in the recall that we would have done that might cause this". I am not so sure with such an extensive repair.
Thoughts?
Thoughts?
#124
Thoughts?
Thoughts?
#126
Stand your ground. Be firm. Good luck.
#127
One of the other things I noticed today was that changing the direction of the flow (feet/face, or just feet) doesn't work. Hot air is always coming out of the upper and dash vents. It was never like that before.
#128
Since they have to take the whole dash apart to do that fix, it's apparent that something was done in there to cause that air handling problem. Res Ipsa Loquitor, as we used to say when we actually learned stuff in school.
#130
...I guess I got lucky...I took my Sc into Sewell in Dallas on thurs(4/10) about 6pm. They called me about 4:30p fri (4/11) & told me it was ready.I just knew it would take 3/4 days minimum, so when they called, I was in Houston in their ES hybrid...lol....so far,so good. I did ask them to take a look at my nav door, because it stopped working awhile back. I had read here that it could possibly come off the track/hinge. The door still isn't working & nothing was mentioned about it,although it was noted on the repair order to look into it
#131
Sounds like it could be as simple as not reconnecting the power to the bend doors, one things that bothers me is what they said without even looking at your car. Go in nice but go in hard like has been said! Good luck. Not Latin, but they "F" ed it up, they need to fix it!
#132
Well I dropped it off this morning and had a nerve racking discussion with the service guy.
He says "Well its been 2700 miles since we worked on it so I don't know if its anything we did". I said "Well I drive it alot but when did I bring it in for the recall?". He says "March 31st". I said "No way I put 2700 miles on it in 3 weeks". So he looks again and says "oh...sorry...I mean 1700 but that is still alot". Well yeah....I do about 100 miles a day for my work commute. Big deal.
I tell him when I got it back it was still cool so I didn't notice that the heat was basically on all the time. His eyes perk right up and I say "Cool outside....not that the climate control was cool". I told him I have never had an issue with the climate control until it came in to his shop. I said I found it hard to believe that everything magically failed right after, and independently of, the dash being removed.
Needless to say I got into work 1.5 hours later and I had a call from him on my voicemail saying that it was a clip that wasn't pushed in all the way.
Of course he also said he noticed that they suggested a new airfilter and brakes last time I was in and wanted to know if I wanted them done. I guess he didn't notice the new filter I installed 2 weeks ago and the slotted/cross drilled rotors and ceramic pad I installed at the same time.
So looks like they will just eat this fix with no extra work order from me. I will just enjoy the GS350 they gave me for the day.
#133
#134
Picked up the car. All is well. The Service Adviser didn't even come out. He sent the keys with their greeter. You would think that he would have at least come out to apologize. The trip added 2 hours to my commute today.
