Driver's Memory Seat not working
Old 07-12-13, 01:38 PM
bjhille
bjhille's Avatar
Default Driver's Memory Seat not working
I thought instead of highjacking someone's thread, I should have created a new one. Please forgive the double post.
I have a 2006 sc430 and have been having problems with the drivers memory seat although the passenger one works fine.
I have disconnected my batter for 5 minutes, moved the passenger seat all the way forward, heard the beep. Moved the reclining part all the way forward until I heard the beep, and the memory seat for the passenger works great.
I moved the drivers seat all the way forward, heard the beep. Moved the reclining part all the way forward until I heard the beep, but the memory seat won't beep (when you hold set and a number). I even replaced my drivers mirror (didn't tilt down due to bad motor), but that didn't help. Of course, I did redo disconnecting the battery and reconnecting it resetting both drivers seat and passenger seat.
I should also add that this is the exact procedure my owner's manual says I should do.
Any other ideas on what could be causing this?
Thanks.
Old 07-12-13, 02:35 PM
FlopTop04
FlopTop04's Avatar
It's possible that the switch itself is bad. I imagine that you checked / verified the harness connection while you were in the door during the mirror replacement. As a test, you could swap the drivers switch with the passengers switch and see what happens.
Old 07-12-13, 03:20 PM
bjhille
bjhille's Avatar
I am happy to report that I am a dork. I pulled the door back off to verify the connections again when I saw that you were right. I didn't notice before because it was already disconnected and tucked behind the vapor barrier. All is well now.
Thank you!!!
Old 07-12-13, 04:23 PM
FlopTop04
FlopTop04's Avatar
Cool. We have all missed things like that.
With my memory seats, the drivers side wasn't working. The SC430 going into the shop for the timing belt / water pump job, so I asked the dealer to check out the memory seat issue. He said it needed the door switch and it would be $400 to replace / fix.
I logged on to Club Lexus, did a search and had it working in 20 minutes....
BXIS250
01-14-24 07:29 PM
kamiraa
10-17-10 09:39 PM
NMLexus
02-13-09 01:51 PM
JZCHAOS
SC- 1st Gen (1992-2000)
11-13-08 05:56 PM
nextlevelcoupe
09-25-03 08:14 AM
Quick Reply: Driver's Memory Seat not working
