LCD panel missing some parts of display
It is possible that there is a bad connection with a cable somewhere in the path.
Agree with Harold...
First thing I'd try is to pop the climate module out, disconnect the 3 multi-pin connectors on the back of it, and plug them back in, to ensure they're seated properly.
If that makes no difference and you're really feeling brave and froggy, there are a few ribbon connectors inside the climate module itself that could also be carefully unplugged and reseated, to make sure it's not the LCD panel itself.
If it is the LCD panel, you'll probably have to replace the whole climate module, as finding the LCD panel alone would be challenging.
My LCD read out for temperature also seems to be fading. But once I drive for a while it is fine. I did recently pull out the AC unit while installing an isimple. I wonder if there is a connection loose? It seems equally as likely the LCD readout is dying, as my car is 11 years old. I had the same problem with an ls400 and would stair at the burned out LCD and be upset every time I looked at it. If my LCD goes I will definitely replace, $300 or $400 on the replacement part is nothing for a Lexus :-)
aumsc400
02-15-06 08:29 AM
