Sprint Booster Review
Hey everyone, I recently ordered and received my Sprint Booster. I ordered it though Ebay about a week and half ago and installed and just wanted to throw up a review of my thoughts on it. First and foremost, the Sprint Booster costs about $300 from Ebay. Installation was easy and didn't require any specialized tools; simple plug and play. It includes the "jumper" unit which attaches to our stock harness and also includes a push button LED remote. As for the performance, I'm not sure of the finalized results in terms of horse power or performance gain, but I will say that my car feels much faster when set in either sport or aggressive modes. You can clearly see the RPM's even at idle increase when the unit is on. It does have an off position which will allow it to return to the stock acceleration for that smooth Lexus OEM feel.
As for the the mechanism in which it works, I will say as explained on many threads on this forum that it seems to readjust the throttle sensitivity. My car now literally launches off the line. This is just as similar, as explained in other posts, as fully pressing the accelerator. I feel that's only partially true b'c the accelerator is more sensitive to smaller amounts of pressure but I also feel that the Sprint Booster pulls more horsepower off the line.
As for the negatives, I would say that the price is the largest deterrent. I feel that the retail price is a quite high for the product, but it does make my car feel like a different vehicle. Friends that have been in my car before and after the install, say it now accelerates more aggressively, similar to BMW's aggressive launch style. The second negative I can specify would be the decrease in MPG. Naturally, as you can imagine, more aggressive driving mean more fuel consumption especially in the lower RPMs. So in retrospect and after about a week of use, I would say that this product, at this retail price is more of a luxury modification. I feel that if the cost was around $175-200, it would have been a truly justified purchase. Anyway, hope this little review helps. Any questions of comments, please feel free to post. Thanks.
Thanks for the review. I have been debating this, as the lag is very annoying. Especially cornering. I never know when to hit the gas so that at the apex the power is winding up. It is like changing your aim off the tee so that your slice golf swing ends up in the fairway. Try your best, but you never really know what is going to happen.
One question. Is this the unit that stays at the last setting, or do you have to turn it on every time?
As for your question: The mode in which you turn off the ignition will be the mode that is engaged when you start the car again. Also, as the instructions explained, you can set the unit to whichever program you'd like with the remote and then disconnect the remote. Your selection will remain locked into the computer. I have yet to test this feature, but I prefer to be able to select the program when I need it. I like to keep it in OFF mode for normal driving (saves gas), but when I'm at at the line with some snotty little BMW I like to drop it into AGGRESSIVE mode.
I don't think so, in both cases the engine RPM goes higher, lower gear may actually prevent transmission damage, but experts here can debate which(if) technique is likely to damage more.....
BluStreak1
03-05-16 02:19 PM
dvzzz
05-18-14 03:05 PM
