This is what I got for $2207.38. Your $.02
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
While it's a large chunk of money all at once, you got a good deal! Assuming they used all Toyota / Lexus parts and you got a free loaner for 3 days, even better. You also have a trouble free vehicle that will give you peace of mind for many miles & years to come plus you created a good relationship with a local dealer. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
The belt was I think $165 to replace the serpentine belt, but then I said that I wanted to also change the timing belt they knocked off I think $100. or more because they had to take off & replace the serpentine belt for that job so I wasn't charged double for the same labor. Same with the water pump. If it had been done later then a lot of the same labor would have to be done again.
Plus I also got a free car wash to boot. Now if I can just find a real good place to have my LuxLink installed all will be right with the world. lol
That milage is a little low to need new rotors. They probably could have turned them and save you some $$. And they might have got you on the serpentine belt. Gatorback belts are better than OEM and cost $20 at any parts store. It's a 5 minute job, so hopefully they didn't charge for labor. But overall, that's not a bad deal.
If I had done the brakes earlier no problem, but I waited. Rides very nice hasn't been that smooth for a while. Don't have the tools (jacks & stands) like I did before the move south. So I don't pay attention to things like I used to.
I had my rotors turned at about 50,000 miles. I'm coming up on 85,000 miles now. And expect to get at least 10,000 miles more. So I think 58K is a little low for new rotors. Unless, of course, you put a few thousand miles on them after they start vibrating. Then you'll warp them beyond repair.
with 65,000 miles on my 06, I had to replace the serpentine belt that was cracking so I decided it was time to change the timing belt as well and the dealer found my water pump was leaking when they opened it up!
Posted from ClubLexus.com App for Android
