SC430 Door Lock Actuator Removal
Old 09-09-18, 02:05 PM
  #46
Harold57
Harold57's Avatar
Cure may not be the proper term, but just letting the glue set up or get sticky/tacky or even just dry to the touch wasn't enough. The package called for a 24 hour cure (my term, I don't remember what they call it) and the first time I only let it set up to where it appeared dry & seemed to be good but wasn't. So I got to tear it apart and reassemble it about 3 times.
DPlainview (11-26-21)
Old 09-09-18, 03:17 PM
  #47
Bgw70
Bgw70's Avatar
hey Harold,
what kind of adhesive did you use?
i only let the JB Weld Setup for an hour and it was good to go.
Old 09-09-18, 03:46 PM
  #48
Harold57
Harold57's Avatar
I can't remember whether it was JB Weld or epoxy, but I'm thinking that I was out of JB Weld at the time (still am) and used epoxy instead. It is called 5 minute epoxy but the instructions state to let it cure for 24 hours.
Next time I'll use JB Weld or go and buy some JB Weld to use. (Better yet, hopefully there is no next time!)
Old 09-13-18, 04:02 PM
  #49
Bgw70
Bgw70's Avatar
My new motors arrived, $1.95ea. Shipping a few dollars.
for the heck of it, I ordered 10 motors...$20, LoL
anyway, they are exactly the same motor I used on both of my door lock actuators and I ordered the extras just Incase I have another problem but mostly because I might have a local friend run into an issue.
this is such an easy fix...I put the old bad motor on top of the package.
Eklectika (06-05-21)
Old 06-25-20, 12:50 PM
  #50
Oceans13
Oceans13's Avatar
Default Open Door light on dashboard after replacement.
Good afternoon. I changed the actuator motors on a SC430 today. The passangers side is fine. However, I haven't been able to get the driver's side right. After I assembled the door, the car thinks the driver's door is open when it is closed. I disassembled and reassembled several times and checked the driver door fuse. Can't figure it out.
Old 06-25-20, 04:02 PM
  #51
Oceans13
Oceans13's Avatar
It was the door close sensor button in the frame. 😅
Old 06-25-20, 06:22 PM
  #52
Buster06
Buster06's Avatar
Ocean,
was it easy to remove the driver side door panel?
I can remove the passenger side just fine. However, the driver side door panel seems to stuck at the top.
Old 06-25-20, 09:53 PM
  #53
Oceans13
Oceans13's Avatar
Originally Posted by Buster06
Ocean,
Roll the window down when you're removing the panel. Roll it back up afterwards. And make sure you disconnect the battery. I had the window roll down onmy hand today.
Old 07-01-20, 10:59 AM
  #54
Oceans13
Oceans13's Avatar
The power door locks work fine but the passangers window button isn't working. The driver's side still controls both windows fine, but the passangers isnt, as if the child window button was on. Any ideas?
Old 07-01-20, 12:15 PM
  #55
Raven01750
Raven01750's Avatar
Well, you have a few things. Most likely it's just the passenger side switch itself. But it could be the passenger door ECU or a wire in between. Do you know how to use a multimeter?
Paul
Old 07-04-20, 06:39 AM
  #56
Oceans13
Oceans13's Avatar
Paul
Good morning, i do not. Is it with the red and black electrodes?
Old 07-04-20, 08:33 AM
  #57
Raven01750
Raven01750's Avatar
Yes it is and it is quite simple and cheap. You can watch a five minute video on YouTube and see exactly what you need to do. If you decide to go the route of doing your own testing. Other than that, check ebay for a switch and hope that is all you need. But I will say that it is highly unusual for the passenger side to go out just because it generally gets used the least.
After looking at some pictures of the switch assembly on ebay, it "may" be possible to take it apart and clean and lubricate the contacts also. But I am an electronic tech by trade so things like that dont freak me out. But a small Phillips screwdriver and some alcohol may be all that is needed. Good luck.
Paul
Old 07-04-20, 09:02 AM
  #58
Harold57
Harold57's Avatar
Oceans13, did you work on both doors or just the driver's side. It sounds like you had both panels off at one point in time. Was it working prior to removing the panel?
If you had the passenger's door panel off, double check the connector plugging into the switch on that panel to make sure that it is well seated. If it is well seated, check the back of the connector housing to make sure that none of the pins have backed out.
When you had the panel off, did you unplug the window ECU also? If so, do the same plug/pin check on it.
Bgw70 (07-04-20)
Old 07-04-20, 09:34 AM
  #59
Bgw70
Bgw70's Avatar
i see you are in Florida, if you are in the Melbourne area, I might be able to help
Old 10-10-20, 03:31 AM
  #60
Bgw70
Bgw70's Avatar
If anyone has a bad door lock actuator, Rockauto has the OEM Aisin brand really cheap right now...$117 drivers side only.
https://www.rockauto.com/en/catalog/...actuator,13257
The following 2 users liked this post by Bgw70:
crosscaddie (02-28-24), Harold57 (10-10-20)
Quick Reply: SC430 Door Lock Actuator Removal
