NAV System Is Not Showing Correct Location
This afternoon I got into Funsize, turned it on, and the Nav system popped up telling me I was in Beaumont, TX. The problem is I am in Houston. Is there a way to reset the NAV system? I have taken the battery off for about 10 minutes, at it erased the memory, but still placed me in Beaumont. I did a quick search, but could not find anything relevant to resetting the unit.
Thanks
Thanks
Did you drive around for a while and it still displayed Beaumont?
Hi Harold. I drove around for 30 minutes and then reset a couple of times. I finally was able to play with the display and options and figured out a way to reset my location by moving the cursor to my location. After sitting last night it still was in the correct location. Unfortunately I don't recall where the options were so I can't recreate what I did!
Hey it's possible the car knows where it is and I don't. Seriously I think there may be something wrong with the nav system. We took a drive about 50 miles away today. About half way home the display showed that we were driving directly north, but we were headed east. I am not even sure how to start checking, but I recalibrated the system. Any help would be appreciated. It is a gen 4 unit in a 2002.
I'd check the antenna connections. It is also possible that the antenna is going bad. (Most remote GPS antennas are active, not passive, antennas, so there is circuitry involved.)
request for screen shot of GPS screen
I have read several places in the forum that there is an indication of connection to satellites on the NAV screen. I cannot recall ever seeing this, but until now the GPS has functioned very well. Would someone send a screenshot of their NAV screen? I have a Gen4 system.
Also, I am wondering if my GPS antenna may have been disconnected when the airbag recall service was performed. This is the first time the unit has acted up, and started after the service where the dash was removed. I have heard of instances where the radio antenna was not reconnected following service..
I don't have a screenshot, but connectivity to a sufficient number of satellites is indicated by the letters "GPS" just under the directional North arrow in the upper left corner. The "GPS" indicator is almost always on, but not in a tunnel or parking garage, or in an area with poor sky visibility (e.g.: lots of tall buildings, like lower Manhattan - I have had trouble in downtown Chicago). I think the car needs to see 3 satellites to determine position.
As for the antenna not being connected after a big dashboard service, that sounds plausible to me, and I think would prevent the "GPS" indicator from lighting up. If that's the case, I would think the dealer would be glad to connect it back up.
Apparently there is a LONG list of tests that can be run to check antenna functioning without removing the dash. The right computer can also recalibrate the NAV unit. Something better than a consumer code checker. Gotta trust the guy - he is good. Apparently the repair involves dash removal though (8 hours?) and the antenna isn't cheap either.
I might be in the wrong place, but can somebody break down this whole navigation thing?
For example, just answer this: is the navigation system more/less efficient and useful than an iPhone?
I apologize if this is the wrong place, but I just purchased a 2002 sc today and I'm inquiring.
To be honest I find a garmin to be easier to operate and much better and more intuitive . I have a dvd player running on my nav screen for MY PASSENGERS PLEASURE !!
Welcome
