Manual shift mode sucks...
Seriously, is there any way to force it to keep the gear you selected? The manual mode only allows me to change the gear at the moment I select it but it doesn't stay there. It still downshifts and upshifts on its own.
I think you're pointing out one specific example where it sort of maybe does what you want.
Example. If I put it in 6th and then floor it, it will downshift even in manual mode. If I come to a stop, it will down shift as I slow down even after I put it in sixth.
If I put it into first manually but then floor it from a step, it will progressively upshift until it reaches 6th at freeway speeds. The manual mode works in that it changes the gear when I tell it to but it won't stay there. It goes back to acting like an automatic.
That's sort of how many older tech manumatics were meant to work. Even a 2013 IS250 that I used as a loaner was like that. The actual gear setting you choose acts as the upper limit and the car's computer decides for you if a lower gear is warranted based on load/engine speed etc etc.
I've figured out that the more you learn how to use something, the less it generally sucks. The more accustomed I get to the selectable shift mode of my SC, the more I enjoy using it. After all, it is what it is. That is to say, it's not a manual transmission.
Exactly.
I am still amazed when people diss on the SC430, or complain about it for what it's not. It's not a sports car. It doesn't have a manual tranny. It was designed as a luxury cruiser, not a tire burner. If those things are really important, by all means a sports car that was meant to be a high performance vehicle should be in your garage!
Personally I was just looking for a nice ride, solid maintenance, nice look and the all important drop top. I got exactly what I was looking for.
I think my ex wife learned well - don't get something and expect it to change <lol>
Right?
Right?
I manually downshift for compression braking, especially on a long downhill grade. It works like my '12 Tundra where your manual gear selection sets the upper limit and the system handles the lower gear shifts.
...as it would in a manual transmission car as well. I'd be fine if it protected itself on the extremes, but it *COMPLETELY* ignores the selected gear after manual selection as though it's in D mode. This results in downshifts at the wrong time when coming out of a corner even with small throttle input changes. My FX45 worked perfectly for this and kept the gear where you selected it. The SC430 doesn't. It's a great car, but the manual mode simply sucks.
