look what santa dropped off
I would go with a spacer on the rear, just to give it that aggressive finished look. Can you tell us the width and offset on the rim? That will determine the width of the spacer.
I still rock my stock wheels. (imo) Wheels resemble RR.
yeah i rocked the stock wheels for a minute but i had these wheels left over from my 22 year old sc400!!!!
could someone post my album on club lexus so everyone could see my car and give me some advice on spacers and mods please
im thinking about a body kit
thanks in advance
thanks in advance
yeah thanks for posting my pics judging from the pics can someone ballpark the size spacer i need?
i measured about an inch or so
any help would be appreicated
thanks again
still line u da man!!!!!
thanks again
how do i order spacers?
i looked on fleabay and it seems so confusing!
i know the size i want is 25mm but it seems that the spacers seem to convert the bolt pattern
from 5x114.3 to something else
please clublexus wheel gurus help!!!!
*Quantity *Two (2)
*Thickness *25mm or 1 inch
*Centerbore *60.1 mm
*Bolt Pattern (PCD) *5x114.3mm or 5x4.5
*Thread Type of Pressed-in Studs & Supplied Lug Nuts *12mm x 1.5 or 12x1.5 or M12x1.5
is this what i need?
thanks in advance
*Quantity *Two (2)
thanks in advance
*Quantity *Two (2)
thanks in advance
*Quantity *Two (2)
thanks in advance
One other tech is proper assembly and torque (~80#)
I've got spacers on my rear wheels and i greatly advise checking YouTube for videos if you plan on installing yourself. All your tech data is correct, as AutoPlak indicated. DO NOT BUY SLIDE ON SPACERS! Go bolt on for sure. I recommend a company called Akata which are "backed" by Vossen Wheels (from what I've been told by a Vossen Rep). There are truly more expensive brands out there to which people will swear allegiance as more reputable companies. I went with the 30mm Black Anodized from Akata, which I installed myself with a torque wrench set to 88 lbs. I have no regrets. Good luck.
ChrisTapia
19
06-02-06 07:02 PM
Swing913
RX - 1st Gen (1999-2003)
08-09-02 12:06 PM
