2007 SC430 Rear Brake Pads (DIY)
I am wanting to change my rear brake pads and could use some help. If anyone has step by step instructions or photos, that would be great. Thanks
Just the pads should be very simple, it's basically three steps:
1. Remove the wire clips
2. Slide the two pins out
3. Remove brake pads
Once you take the wheels off and get a good look at the whole assembly it is relatively easy to figure out.
