Suspension - which coilovers to go for?
Hi Guys,
im sure this has been spoken about before but I thought I would ask my specific questions.. I dont know how many people find the sc's shocks any good but I find them to be stiff. I mean there smooth but any bump or crack in the road and I feel it, sometimes enough to rattle stuff. Whats wierd is that sometimes it feels comfy but sometimes stiff, hard to explain.
I would like to lower my car very slightly, perhaps an inch and half but also have more comfort. I remember Bacardi recommended blistein, but I dont know how much modification that requires so I would like to avoid custom work and if i ever swap my car I will take them out.. someone mentioned meister's? I have also seen megan's.. Im not looking for something expensive.. Decent but very nice and comfy
if you have any on please tell me what difference you felt and how much better the ride was, and if it solved any issues for you?
Thankyou !
Thankyou !
but your saying coilovers wont be more comfy? :S im just looking for something very smooth and comfortable, I dont mind sporty feeling but something that makes your car feel like its a $100k car.. but again im not looking to spend a crazy amount on this.
Thanks
Hi Bimmer
I am with Cheez on this, I have Megans on mine and even on the lowest (softest) setting they are firmer than OEM.
I have converted to air now using the Megans and it is even firmer than before, but I am happy with a firm ride.
Coilovers are mainly to improve the handling rather than the ride.
If you drop the car using shorter spings on OEM shocks the ride will be firmer because the spring has less travel. With coilovers you can drop the car, but keep the same ride because the spring is moved up (or down) on the shock without affecting the length of it.
Hope this helps.
Cheers
Steve
Hope this helps.
Cheers
Steve
I am at this point that I **** to lower my car and maintain a comfy ride. I have read a load of posts on this forum about coil overs only to give myself a headache and leaving me unsure which route to go. Like the OP related I too want to lower the car while bettering the smoothness of the ride.
The Tiens are attractive but my gosh they are expensive. Do the other coiloevers work just as well at a far cheaper price
also, to reiterate -- seems like a lot of people think you can go lower without sacrificing ride comfort, but that's like having your cake and eating it too. the lower your car is, the stiffer the suspension needs to be to prevent the chassis from hitting the ground. comfort and lowering are mutually exclusive, generally. of course, your ride quality won't change much if you lower your car 0.5" with lowering springs, but coilovers are a different beast.
Your post interests me greatly as I am not really up on shocks, springs, etc. I have a body kit on my car and so I cannot lower my car but so far. If you say lowering springs to lower the car a half of an inch will not alter the ride comfort then that is all I need. If I were to get the coil overs I would not lower the car past a 1/2 inch. Could you recommend a good setup with the lowering springs (shocks, etc if that is necessary) that would give me the most comfortable ride with the lowering springs. Or at least point me in the right direction and I will take it from there
Hi Bimmer
Hope this helps.
Cheers
Steve
Hope this helps.
Cheers
Steve
Mo
But in terms of which coilovers, what would you guys recommend? Im looking at meisters, megan, bc (someone is selling on sc classifieds), bilstein (but I dont know if they sell a package for the sc, I dont know exactly what I will need).. Im avoiding having to put stuff together if you guys know what i mean? Just want something I can put in myself and perhaps get a shop to adjust?
and here is what i saw on meisters website,, im wondering if the other brands are similar specs to this, what do you guys recommend and for the best price..
Thanks guys
![Suspension - which coilovers to go for?-coilover-1.png](https://www.clublexus.com/forums/attachments/sc430-2nd-gen-2001-2010/311981d1461366886t-suspension-which-coilovers-to-go-for-coilover-1.png)
I honestly dont know if im going the coilover's route but i will speak my opinion..
im going Air Suspension.. however...
im doing the universal bag UAS over stock struts...
i want to keep my oem quality but just advancing the adjustments...my initial ride height with the Air Suspension will be .5 - 1 inch higher than stock height... but i can still lower my car if i want a bit more performance at any height i litterally want.
its like installing springs to lower my car 1 inch i can also do that with the air suspension...with the Accuair E Level i can comfortably do it.. but at the same time i can have the stance and parking lot dump also but i wont be driving that low at all...
so i can get bits of pieces of all worlds...some maybe against it but i dont track or anything with my SC..its my daily..you adjust your car to how it fits your way of driving...
i thought about putting the UAS bags over Megan Coilovers ... thats always an option for future reference for me.. thats if i plan on doing crazier stuff to my SC
How much the size, quality and the specification of wheels/tires affect the quality of ride? I remember a post, someone changed to 17" wheel size with a fat tire had a smooth ride but was it floating? not sure.
Hi Guys,
My SC rode smooth except that any little bump or crack in the road caused my teeth to jar. I ditched the run flats and it made a world of difference.
JR
I am on air with Megans. The dampers have to be adapted. The bag has to be at the bottom of the rear damper because it will not fit within the arch at the top. I have sports bags, but you say you are using universal, maybe they are smaller in diameter.
The higher you go with the bag the stiffer the suspension gets and the lower you go the softer it gets, but then the bag can bottom out and the ride can be bone jarring.
Do a lot of research before you pull the trigger because in my opinion you may not be able to get the OEM ride quality you want.
Mine is certainly nowhere near OEM, but I am happy with that.
Zack @UAS will be able to answer your questions, but make it clear you want a soft ride.
cheers
Steve
The car is a different animal with the coilovers, firm but comfortable with no 'floating boat' feeling and very little roll when cornering.
Dampers work in both directions, up and down. Sports dampers help to keep the car level when cornering hard by stopping the outside lifting and the inside dropping. Hope I have explained that okay!
I went over to air because I like to run the car fairly low, but I am able to lift it instantly with the touch of a button on the Accuair touchpad to get over speed bumps etc.
I have not heard of another SC with Accuair in the UK.
Cheers
Steve
