TPM confusion
Have an 05 SC430. Bought a second set on Lexus rims with winter tires off a guy. Put them on last winter, obviously the TPM sensor blinks - so I take the car to the dealer to get the sensors programmed on the new tires. Zero problems, works fine. So summer comes around and I put the original wheels back on and push the TPM button under the glove box and again zero problems and works fine. Now here is where I am confused, This winter I put on the winter tires and did NOT push the button and the TPM light never came on?? Can the dealer set all 8 wheels to the same code or something like that?? Why would that light not blink without pushing that button.
Also: it will still blink if the tire pressure is low.
I think that it takes some time for the computer to realize that the programmed sensors are no longer on the car.
Not sure but what happened to me is that I bought a SC430 and had it shipped from out of state. After about 100 miles I got a blinking TPMS light. I brought it to the local dealer and they told me that the programmed sensors did not match the ones in the wheels of the car. They said it takes about 100 miles or so before the computer would catch it and flash the light. Solid light means low pressure.. Blinking light means malfunction.
They programmed the car for the current sensors and it has been fine for a year. It has reported low tire pressure when I got a nail in a tire after that so it works fine.
JR
JR
In regards to my experience with the TPMS, I recently had winter runflat tires mounted and found that after a night, I woke up to the TPMS on in a blinking state and beeping every 5 minutes. I stopped to check pressure and my front right tire was 0psi. I filled up air and went on to work as I didn't have time to investigate further, when I got out of work the light was on again and in a solid light state. I check the tire and it was down to 25 psi. It seems that the mounting shop ruined my all four of my chrome rims with their mounting machine (going to small claims court soon). I later had the bead leak repaired at another shop, and now no light. I feel that if the psi drops to a certain dangerous point (or malfunction as FLYCT stated) then the solid light turns to a blinking light with the audio warning, indicating "get help immediately". Just my impression, though.
PS. I'll be starting a thread on the wheel damage soon for opinions on what I should do as I've never been to small claims court, and would appreciate any advice.
Here's my recent experience regarding TPMS sensors. I purchased a set of G-Spider wheels from a fellow CL member. The wheels came complete with good rubber and TPMS sensors. The wheels came off a Lexus IS 350 AWD. I installed the wheels and pushed the switch in the glove-box to the position for a second set of sensors. So far the light is on solid. Took the SC to the local Toyota dealer and they were unable to register the sensors to my car. They said that they called a Lexus dealer and apparently the sensors that work in the SC's are color coded and the sensors from an IS are not. Therefore, the Lexus TPMS sensors in my G-Spider wheels are not compatible with the SC. Bummer. As long as the light simply stays on solid, and there are no beeps or other distractions, I'll be fine with that.
StillLine
![](http://s14.postimg.org/wjsnvqjdt/G_Spider_4.jpg)
StillLine
Sorry to hear about your woes. Rims look great tho! I'm in a similar situation. I was told to write down the frequency code on each sensor to help Lexus program them. But the seller who sold them to me (via this forum) told me they were from a 02' SC430. I took them to the local dealership to confirm that they were OEM Lexus parts and compatible to be programmed at a later date. According to Sewell Parts Online and as you pointed out, each color is coded to a position on the vehicle. So far so good. Haven't mounted the new tires and rims yet due to the continued winter weather, but will update with either my celebration or disappointment in regards to the TPMS. How much were they estimating the reprogramming before the incompatible "incident."
StillLine
StillLine
Just to reconfirm how the TPMS warning light presents itself, today when I swapped my winter tire/rim set out and put on my OEM rim/all season tire set, I purposely did not hit the switch. All my tires were set at 35 psi already. Upon starting the car and driving about 100 feet, there was a flashing warning light with a beep. The warning light remained on and the beep continued every 2 or 3 minutes even after I hit the switch in the glove box to tell the TPMS to read my OEM set sensors. But the warning light and beeps stopped after another 2 miles of driving. So I conclude that my TPMS set is all in good working order.
Blueshark
ES - 5th Gen (2007-2012)
11-29-11 03:45 AM
